Updating Distributor?
Discussion in 'Electrical Systems' started by Shruted It, Jun 1, 2019.
  1. Shruted It
    Shruted It New Member
    15
    Sep 2, 2018
    Hi All,
    Hope this thread topic is in the correct place..
    I have a '72 Camaro that currently has a 1969 SBC 350 engine. The motor has a points distributor and before it starts giving me trouble, I was looking to upgrade to an electric distributor. I was looking for something that would basically plug in using the existing hookups (minus the ballast resistor of course). HEI looked to be more involved than I was interested in.
    I've seen some ready to run distributors online that look to be a good replacement for points. Any suggestions on something that would match my needs? I do have an MSD 6A and coil in a box if needed as well. Motor is mild so nothing extreme needed.
    I appreciate any advice or tips from others past experiences.
    Andrew
  2. dave@ztech
    3,404
    703
    Mar 27, 2016
    NY
    Are you having trouble with the point? Or just have some money burning a hole in your pocket? There are easy conversion kits from Pertronics that you can convert your existing unit to, or upgrade to the better MSD unit and install the stuff that you have in the box.
    Shruted It likes this.
  3. COPO
    17,689
    684
    After my Pertronix died I went with the Crane X R-i
  4. Zspoiler
    Zspoiler Veteran Member
    3,213
    252
    May 6, 2012
    Federal Way, Washington
    You can also use an MSD distributor .with an standard style cap.So it looks fairly stock.
  5. Shruted It
    15
    Sep 2, 2018
    No trouble with it but since ill be swapping cam and intake, I figured while distributor is out I'd upgrade it as well.
  6. Gary S
    22,428
    759
    GM factory HEIs are a direct plug in except for adding a wire to bypass the resistor wire.
  7. tom3
    tom3 Veteran Member
    11,923
    327
    Aug 1, 1999
    ohio
    One of the best updates I've made to the points ignition is to trash it completely. Put in an HEI distributor and forget the maintenance and misfiring problems.
    G72Zed likes this.
  8. dave@ztech
    3,404
    703
    Mar 27, 2016
    NY
    I have never had a problem with points all the way up to 6500 and beyond
  9. G72Zed
    G72Zed Veteran Member
    1,080
    235
    Sep 8, 2015
    One of the better companies out there building nice HEI w/custom curves with your specs and options is Steve Davis of DUI (Davis Unified Ignition)
    Not cheap, but very well built and on the money. I had a 20$ junkyard HEI for years that I modded as I went, just worn out, very satisfied with DUI.
  10. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    HEI and put a mechanical advance upgrade kit in it. Make sure the vacuum advance works. Good brass terminal cap and rotor. Ignition power source that it full 12 VDC for start and run. Done.
