Upgraded Cooling System Necessary for 408?
Discussion in 'Engine Topic' started by Powers76, May 13, 2013.
  1. Powers76
    Powers76 Veteran Member
    405
    Jan 28, 2008
    Salem, Oregon
    I know there are many different opinions and wives tales about the 400sbc but I was just curious if someone who has ran one can confirm if it actually requires a beefed up cooling system or will my stock 350 radiator suffice. Thanks in advance.
  2. Lowend
    15,013
    481
    Mar 25, 1999
    San Jose, CA, USA
    That's pretty general... what kind of condition is your current radiator in?
  3. Powers76
    405
    Jan 28, 2008
    Salem, Oregon
    Sorry. Its just a stock radiator from 76 Camaro 350. The radiator is in good condition, Ive never had any problems with leaks or overheating. A coworker who seems to have it out for 400's was telling me I need to get an aluminum radiator and a high flow water pump before running it or it will get hot and the block will crack :screwup:
  4. dale68z
    dale68z Veteran Member
    1,362
    22
    May 14, 2009
    Glendale Arizona
    I am running a 408.
    I run road course track days here in Phoenix and the car has AC. It is a very strong engine.
    I initially had a champion radiator, 3 row .75" tube it would keep the car cool driving around town,but the engine would get to 240 after about 10 minutes on a road course. After champion warranteed the radiator, and then replacing the water pump with a high flow victor series edelbrock, installing a stewart high flow t stat and adding hoses to allow water from the front to the rear of the intake, with no change in temp. I cut apart my 3 month old radiator and found champion radiators are junk.
    I bought a 300$ griffin rad, 2 row-1.5" tube from summit and my problem was solved.
    Sooo, I believe a good stock radiator should be sufficient. Especially if not racing, and a more mild climate
  5. SpeedAddict02
    SpeedAddict02 Veteran Member Lifetime Gold Member
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    I think as long as everything is in good condition and working properly, stock stuff should be fine..
    I ran a vortec 406.. I had a stock replacement radiator, electric taurus fan and stewarts water pump.. If i used a good fan clutch i think it would have rub just as good. Also a 180 stat.. 90% street use.
  6. Powers76
    405
    Jan 28, 2008
    Salem, Oregon
    Thanks for all the input. I dont even like bringing up my engine around him lol all he talks about is how 400's are crap and how I should have bought this, that, and the other. Ill just have to show him how wrong he is :bowtie:
