Urethane transmission mount - noisy?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ULTM8Z, Sep 28, 2019.
  1. ULTM8Z
    ULTM8Z Veteran Member
    9,183
    355
    May 19, 2000
    Los Angeles
    Need to replace my transmission mount. Anyone have any experience with urethane mounts?
    Do they result in a noticeable increase in noise being transmitted into the interior of the car?
  2. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    I’m running the urethane mount. I noticed no change is cabin noise with the switch. The mount is definitely better than the stock rubber one.
    hubedobeedo likes this.
  3. hubedobeedo
    hubedobeedo 3rd times a charm
    491
    154
    Jul 18, 2013
    Huntertown,IN
    i got some Teflon grease and put a light coat on contact surfaces no noise at all did to all urathane bushings used. actually have used the grease on some thread and other contact surfaces as it is anti corrosive. used on my daily driver truck when i rebuilt front end connections are still good after 4 years and indiana salt
  4. GoldenOne7710
    4,825
    417
    Jun 23, 2004
    Athens, GA
    I have Energy Suspension engine and transmission mounts. Never heard any noises from them. Also have poly swaybar bushings, but at least they have zerks on them so they can be greased. They've never squeaked either.
  5. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    I only use polyurethane for mounting, not for anything that rotates or articulates. It will eventually squeak when used for that purpose.
  6. biker
    biker Veteran Member
    910
    94
    Dec 7, 2014
    New Liskeard Ontario Canada
    Poly engine and trans mounts. No problems, stiffens things up nice
  7. ULTM8Z
    9,183
    355
    May 19, 2000
    Los Angeles
    You guys are saying you saw no increase in drivetrain noise being transmitted into the interior?
  8. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    Right...I heard no additional noise or change after installing poly mount.
  9. CorkyE
    10,376
    471
    Same here.
  10. biker
    910
    94
    Dec 7, 2014
    I think it actually improved. The stick on my trans used to noticeably flop around. Not so with poly mount.
