VA EZ clamps help?
Discussion in 'High Tech Retrofits' started by badazz81z28, Feb 9, 2019.
  1. badazz81z28
    15,456
    229
    Las Vegas, NV
    Do these pinch or just clamp with the clasp? They do not look like traditional pinch clamps I’m used to. I planned to use normal pinch clamp pliers, but the VA clamps look different. Help please.
  2. wnmech
    wnmech Veteran Member
    846
    60
    Jul 20, 2014
    grand prairie tx.
    I'm assuming you are talking about the hoses getting crimped onto the fittings? If so on my VA air system I measured and cut and marked the positioning on the hoses and fittings and took them down to a local business that deals with automotive air conditioning and they crimped them on professionally for I think $5 dollars a hose. Otherwise due to the pressures you need a special tool.
  3. badazz81z28
    15,456
    229
    Las Vegas, NV
    ^ negative, I have the tool for traditional crimps. These are EZ fittings
  4. reedld
    reedld Veteran Member
    262
    Aug 9, 2007
    Painted Post NY
    I bought the va pliers specifically for the ez clip system...sadly I have not used them yet. Good luck.
  5. czizza
    czizza Veteran Member
    913
    27
    Jan 8, 2004
    N. Massapequa, NY, USA
    I found a video not sure if it helps
