Very fast idle
Discussion in 'Troubleshooting & Diagnosis' started by valleyguy, Apr 17, 2019 at 10:16 AM.
  1. valleyguy
    valleyguy Member
    79
    Jul 15, 2018
    So I finally got my 71 Camaro engine running, Yea! but it is revving way too high. Stock 350 engine with automatic trans. I did install better flowing heads and, just this week, a new Edelbrock 1406 carb with automatic choke. No other changes to the motor. I can't figure why it's idling so high; No vacuum leaks that I can tell; anyone have a clue?
  2. COPO
    17,108
    427
    Your choke is on for one thing. When fully warmed up, loosen the choke screws and turn the dial so the choke plate is fully open then lock the screws down. If needed, turn down the idle screw as well.
  3. Rascal
    Rascal Veteran Member
    259
    Apr 18, 2002
    Severna Park, MD
    How did you eliminate a possible vacuum leak? My recommendation would be to place a folded rag over the carburetor while the engine is running. ENSURE the rag is of at least double the size of the carburetor opening and folded a few times. An old towel works well for this test and is better than bare hand in case of backfire.
    The engine should stall immediately, if so this should confirm no vacuum leak(s).
  4. valleyguy
    valleyguy Member
    79
    Jul 15, 2018
    Thanks gents, well it wasn't a vacuum leak, it was the choke.
