vibration issue
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 1981zapper, Sep 28, 2019.
  1. 1981zapper
    1981zapper Veteran Member
    1,381
    Apr 28, 2009
    Southern Ontario, Canada
    Ever since I've owned my car its always had a vibration issue at highway speeds, I figured it was from the worn out suspension and 30 year old tires, at 3500 RPM the steering wheel and dash shake like you would not believe.
    Anyways I finally got around to installing all new, Suspension bushings, ball joints, inner / outer tie rods, center link, idler arm and new rims and tires
    Today I got my tires/ rims installed and got an alignment done, the drive is a lot better but I still have a vibration issue at 4000 RPM and up
    One thing to note:
    I've always wondered why, my car revs so high on the highway, I have 3.73 gears, turbo 350 (non-lock up) and 275/40/17 (25.67")
    At 63 Miles per hour I'm revving around 3650 RPM, which from my online calculator with my set up I should only be revving at 3,076 RPM
  2. Twisted_Metal
    26,944
    925
    Are you sure you have a V8 tach?
    Do you have the correct speedometer gears for a 3.73 rear?
  3. COPO
    17,682
    683
    I kept my 80 Z28 for 10 yrs before selling it and never had a vibration issue. Maybe the driveshaft balance weight came off or you have a loose flex plate bolt or the universal is shot.
  4. 1981zapper
    1,381
    Apr 28, 2009
    its the factory z28 tach
    no I do not have the correct speedometer gears, as my speedo is off, I verified my speed with my Garmin GPS
  5. 1981zapper
    1,381
    Apr 28, 2009
    I had a look at the driveshaft still has weights on both ends of it, u-joints are tight
  6. COPO
    17,682
    683
    Ever check the pinion angle?
  7. 1981zapper
    1,381
    Apr 28, 2009
    No, I will have to check it out over the winter
  8. Gary S
    22,410
    752
    These cars never had vibration issues when they came off the assembly line. Knowing that, look over the car carefully for any drivetrain part that isn't original as some change along the way is likely the problem.
  9. shanghai Kid
    shanghai Kid Veteran Member
    171
    65
    Jul 5, 2010
    Give them motor mounts a looksee
  10. rchydzik
    833
    22
    Nov 13, 1999
    Colbert, WA USA
    With respect to the RPM, you will get some slip with the torque converter (100-200 rpm), but more likely the tach is reading fast. This seems to be very common. Mine was about 10% off reading fast.
