Vibration when stopped at light.
Discussion in '1970 - 1973 Specific' started by john Gialanella, Mar 21, 2020.
  1. autobahn
    autobahn New Member
    27
    Jun 8, 2005
    55963
    I'm in the exhaust category
  2. Rosster
    Rosster New Member
    16
    Mar 1, 2020
    In my younger days (mid 70s) that’s all we had!
  3. GMChevyOnly
    GMChevyOnly New Member
    May 5, 2012
    Hawaii
    I use Bosch Platinum +4 spark plugs, I can feel the difference. Tried NGK Platinums and Iridiums but my SBC 350 runs best with the +4s.
    cadillac_al likes this.
  4. john Gialanella
    john Gialanella Veteran Member
    286
    12
    Oct 15, 2008
    Bloomfield N.J.
    I took the SS 396 out today for 20 mile run. When it started to make noise I gave it gas and it went away, same as when I put it in neutral. I checked under the car from the side and the two mufflers had about a 1/2 inch clearance from the floor pan. In warmer weather I will go under the Camaro (I am getting to old for that) and see if a hanger is broken. Camaro has headers on it (I have the correct BB exhaust manifolds) I will check to make sure the bolts are all tight. As for the torque converter wouldn't it also cause vibration when I am on the Highway. I have no vibration on highway.
    John.
  5. ULTM8Z
    ULTM8Z Veteran Member
    9,314
    454
    May 19, 2000
    Los Angeles
    I think some part of the exhaust system is hitting resonance like I was saying in an earlier post.
    Is this something new? Could be a hanger is broken, so the stiffness of the system changed and now the resonant frequency of the system is in band with with the engine at that rpm.
  6. cuckoodawg3132
    cuckoodawg3132 New Member
    Feb 23, 2020
    I had a 76 type LT with a 350 and I had a vibration that drove me nuts, come to find out it was one of the exhaust pipe hangers. Just give a little tug on all exhaust components and see if anything is not secured.
  7. wnmech
    wnmech Veteran Member
    970
    116
    Jul 20, 2014
    grand prairie tx.
    You mentioned in post #24 about checking under the car and having a half inch clearance in neutral you really probably need to pit the car on 4 jack stands and put car into gear and see if the exhaust system shifts just enough to cause the rubbing vibration. Could be a worn motor mount shifting the engine just enough to cause what you are feeling.
  8. jbloake
    jbloake Veteran Member
    357
    85
    May 1, 2002
    Atlantic Canada
    John in post one from what I understand you shift to park and the vibration goes away. That’s telling me the fluid pressure on the vanes changed , causing the vibration to stop. Same when on rolling along under light load you are getting the vibration, then load up the pressure it goes away , From post 24 it seams to be more of a noise than a vibration . Somebody else must be an trans guy that would know better. It just sounds like torque shudder to me .
  9. john Gialanella
    286
    12
    Oct 15, 2008
    Bloomfield N.J.
    In warmer weather I will check hangers on mufflers. Also I have been meaning to take Camaro to Transmission place to replace trans fluid. I can ask about Torque converter. But I am concerned that guy can say that that is what it is (when it is not) to make money. I will search on internet for problems caused with bad torque converter.
    John.
