Vincent's 72. "EL Maro"
Discussion in 'Project Progress' started by broahnazki, Oct 16, 2016.
  1. broahnazki
    broahnazki Veteran Member
    247
    27
    Jan 19, 2014
    los angeles
    Had my fuel pump come in. I had ordered this thing a while back and summit was kind enough to exchange it with the correct one at no extra charge. No I don't care about mixing jegs and summit as u can see in the pic. I Checked over all my fittings and decided on using riveted nuts on the car to clamp the fuel hose as well as the filter/regulator. Also Since I can only do bodywork on the weekends that's what I'll do and during the week I'll start taking on small jobs. I need a game plan to get it running by the time summer rolls around. There's definitely a classic car scene here in Washington (Seattle area) it's like a rainy LA and I'd hate to miss out on it this summer. Btw I'd like to thank coverman66 on YouTube not sure if he's a member here but this guy has A lot of knowledge with Ls swaps should check out his channel, has tons of content. IMG_0821.JPG
  2. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Well guys I finally sprayed some primer over the quarter. I know I haven't updated on the bodywork these past weeks as I went home so I didn't touch the car. Anyways here's what I did and how it sits. I'm literally updating as I'm doing it right now
  3. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Well my phone service sucks in the booth. I don't know it didn't send the update... well here's some more pictures. This is 4hrs later. I set it to cure in the booth so.. IMG_0835.JPG IMG_0837.JPG IMG_0839.JPG
  4. webfeet69
    webfeet69 New Member
    9
    Feb 13, 2017
    Very nice!
  5. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Thanks
  6. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Hey guys I'm back I know I haven't posted in a bit. I haven't really been able to put some work on the car with work and everything in between . So I began sanding down the doors (pass side) and if you guys have been following my thread you'd see that I did a bit of work to them well now I started to block them and so far so good, I also put an old hacked up hood on the car to see how much and where would I cut to make the intake fit and I gotta admit I was pretty surprised that it barely needs any work to it. I did however realize that I have solid body bushings and I have them at the Lowest level all around so I may flip them and see what else I may need to do? IMG_1038.JPG IMG_1043.JPG IMG_1044.JPG
  7. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Well it's about freaking time! It's been a while since I've posted but I've just been buisy. I layed three coats of primer today now just a guide coat and see where I'm at IMG_1390.JPG IMG_1399.JPG IMG_1401.JPG IMG_1412.JPG IMG_1413.JPG
  8. 7/3-SplitRS
    7/3-SplitRS Veteran Member
    210
    25
    Mar 26, 2014
    Pecatonica IL
    Just read your entire thread, been making some really fast progress with this thing and have covered a lot in a short amount of time. My daughter is in Silverdale WA, she is in the navy.
    I appreciate your service to our country, will be following the thread. Looking Good!
  9. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    So I was sanding the trunk lid and the low spots are very weird, is the trunk lid supposed to be like this? As in "dip" on the upper corners? IMG_1427.JPG IMG_1428.JPG
  10. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Well guys I kinda hit the car hard this weekend, sand blasted a few parts and primed em, took the mirrors apart, blasted the wheels and Finnished the door, finally! hopefully I get the paint for the wheels this week aswell as some sealer to start getting this thing painted! I'm at the stage where I just want to Finnish this thing! IMG_1452.JPG IMG_1453.JPG IMG_1454.JPG IMG_1455.JPG IMG_1463.JPG IMG_1464.JPG IMG_1465.JPG IMG_1466.JPG IMG_1467.JPG IMG_1471.JPG
