Vincent's 72. "EL Maro"
Discussion in 'Project Progress' started by broahnazki, Oct 16, 2016.
  1. Da-bigguy
    3,716
    131
    Jan 19, 2010
    Cypress, TX
    Your car is looking fantastic!! I wish I had the time to spend doing as much as possible on my car myself. Hopefully when I get back home, I will be able to get in the garage on a regular basis for a few months and get a bunch of stuff done on mine!
    broahnazki likes this.
  2. broahnazki
    broahnazki Veteran Member
    247
    27
    Jan 19, 2014
    los angeles
    thank you, every chance you get is a step closer just take it one thing at a time, with winter around the corner im sure your car will start to come together ;)
    Da-bigguy likes this.
  3. Da-bigguy
    3,716
    131
    Jan 19, 2010
    Cypress, TX
    Thanks, the biggest problem I've had lately was no cash to spare for the Camaro after getting laid off. Now that I've got some regular cash coming in, I can start working on it again. My next big step is to get the body media blasted to see just how much steel I'm going to need to replace. While that is getting done, I'm planning on getting the front end together, finish off the repairs to the subframe, blast and coat it once that is done and then start assembling the front suspension and steering components.
  4. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    do it, blasting mine was the best thing i coulda done, I saw rust holes where i never would have looked if i was just grinding everything off.
  5. Da-bigguy
    3,716
    131
    Jan 19, 2010
    Cypress, TX
    I'm definitely getting it blasted! I found fibreglass repair patches in the wheel well area while taking things apart. Depending on how bad they are, it could be a good excuse to go with mini-tubs and wider wheels! I do need to keep the two back seats though, for when I take the family out for a drive.
  6. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Didn’t get much done today just a couple of small things, did manage to strip the g braces.
    As someone who loves spray painting I think they came out pretty good!
    After doing a bit of scanning through I decided to try something out, I noticed a lot of old school mags had the cast textured look and figured I’d try that with the stock z wheels. Without much knowledge I figured a textured paint Would do the trick and so ...
    For this I used rust-oleum texture paint.
    It did spray very hard and it’s a very strong smelling paint. Not like your average can where you can lightly press and release, if you do plan on trying this I recommend you keep a good distance.
    As for color I decided a flat nickel would give the cast look a nice pop and I think it did, but I wish I had gone with a darker color.
    And the end result !
  7. broahnazki
    247
    27
    Jan 19, 2014
    los angeles
    Not sure my camera got the texture on the wheel Verry good, but I’m happy with the way these turned out, now I’m just gonna save up for the stainless brushed trim rings
    After 2 light textured coats 3 color coats And all sealed up in 3coats of flat clear they came out pretty solid.
  8. dave@ztech
    3,274
    657
    Mar 27, 2016
    NY
    They look great, and the color, maybe a little lite, however, I think they look great!
  9. Smokey15
    Smokey15 Veteran Member
    2,949
    1,172
    Aug 13, 2017
    Caledonia, MI
    Good idea on clear coating them. That will make them more durable and easier to clean.
  10. steve vuk
    steve vuk Vuk
    49
    Oct 30, 2018
    Ny
    Great color and amazing work
