Vincent's 72. "EL Maro"
Discussion in 'Project Progress' started by broahnazki, Oct 16, 2016.
  1. broahnazki
    broahnazki Veteran Member
    255
    57
    Jan 19, 2014
    los angeles
    IMG_0654.JPG Hey guys, quick update here. So here's the result in the car. It didn't turn out to bad for my first time. I noticed that the panel was slightly warped but nothing too serious. IMG_0647.JPG I tried taking pictures from different angles but kinda hard to tell. Overall I'm pretty happy with the way it came out. IMG_0645.JPG I still have to Finnish the bottom of the panel (pic was taken before I fully welded it), as you can see by following along the lower section it kinda looks a little off. Maybe that's what makes me think it's warped? I'll update later this weekend.
    brooksman9 likes this.
  2. hot72rod
    3,014
    37
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I step away for the site for just a little bit and you go to work on the car big time. Good job.
  3. hoppin5478
    581
    98
    Jul 20, 2015
    Tucson, AZ
    Nice job! I'm getting ready to tackle the same area on mine but the patch needs to be slightly larger. I hope mine turns out as nice as yours looks.
  4. broahnazki
    255
    57
    Jan 19, 2014
    los angeles
    Thanks man I had too, I felt like I wasn't getting enough done. The weather up here in the northwest sucks to work on the car in the open.
  5. broahnazki
    255
    57
    Jan 19, 2014
    los angeles
    Good luck. It's not so bad, Just take your time.
  6. hot72rod
    3,014
    37
    Aug 9, 2000
    Since you have put the LS in, have you checked the clearance of the alternator to the hood.
  7. broahnazki
    255
    57
    Jan 19, 2014
    los angeles
    I did, the intake would clear with a 2inch cowl hood but the alt sits a tad bit too high. Looking at changing the bracket soon
  8. hot72rod
    3,014
    37
    Aug 9, 2000
    If you need a cowl hood to clear, you are probably still going to have the same problem whit a new hood. The underside of a still cowl hood around the TB area is the same as a stock flat hood. Now that not to say you will be able to trim the bracing to clear.
  9. broahnazki
    255
    57
    Jan 19, 2014
    los angeles
    I forgot about the bracing. Yea might have to trim it but don't want to mess with the integrity of the hood. I'll prob have to re enforce it somehow
  10. AllensaurusRex
    AllensaurusRex Veteran Member
    538
    32
    May 22, 2013
    Murfreesboro TN
    yeahhh buddy. you are MOVING on this thing.
