Vintage air removal
Discussion in '1970 - 1973 Specific' started by gpm6367, Jun 17, 2019.
  1. gpm6367
    908
    46
    Feb 12, 2005
    New Joisey
    That’s brilliant...
  2. gpm6367
    908
    46
    Feb 12, 2005
    New Joisey
    Officially looking for a 1970 Camaro owner who wants a used vintage air system and will discount for all your original heater only parts that you will remove. Good deal for all.
    hubedobeedo likes this.
  3. flht99b
    flht99b Veteran Member
    206
    37
    Nov 28, 2014
    Knoxville, TN
    Not committing to anything but I have a real 1971 Z28, rotissiere restored, that I might want to put AC into. All the factory heat/defrost and outside air parts function. I have no idea if 70 and 71 are the same parts. I'm in Knoxville Tennessee.
    gpm6367 likes this.
  4. gpm6367
    908
    46
    Feb 12, 2005
    New Joisey
    At the risk of sounding judgmental, why? A rotisserie restored Z28? If for no other reason than to devalue car I would be reluctant, but obviously your call.
    As soon as I can get refrigerant recaptured I am yanking entire system and will lay out and photograph.
    I doubt the heater equipment from 70 to 71 would vary. Anyone know for sure?
  5. flht99b
    206
    37
    Nov 28, 2014
    Knoxville, TN
    My car is a mild resto mod. Original Muncie is long gone, replaced with a TKO600 5speed. 4 wheel disc brakes, upgraded suspension, steering box, electric fan from a Taurus, etc. Short block is the factory/dealer replacement when original blew up. Although I'm still on the fence about adding A/C to it, would have been nice to have during the Hot Rod Power Tour last month. I modernized and up dated car for today's environment so I could drive it. Aluminum heads, modern cam, electronic ignition are all things I wouldn't go back to 1971 for.
    gpm6367, hubedobeedo and xten like this.
  6. gpm6367
    908
    46
    Feb 12, 2005
    New Joisey
    That actually makes sense. If interested let me know.
  7. 70lt1z28
    3,316
    652
    Oct 3, 1999
    Beavercreek, Ohio, USA
    HVAC system is identical from 70 to 71.
    gpm6367 likes this.
  8. BigBlock73
    2,022
    60
    Jul 10, 2002
    Accord,New York
    For my knowledge.
    Whats the difference between the 70-73 non AC/ heat only stuff?
