Vintage Air
Discussion in 'High Tech Retrofits' started by ATM, Feb 6, 2011.
  1. 71RS/SS396
    71RS/SS396 Veteran Member
    2,630
    31
    Aug 26, 2008
    Wake Forest NC
    I don't think this is true as I understand it any mechanical control can be converted. I will confirm this and let you know.
  2. sickracing
    sickracing New Member
    Feb 9, 2011
    chicago
    Compressor Clearance
    O.K,,i need someone to clarify a couple of a/c mounting questions. 80 z28,,installing a complete 2000 ls1 with pstr. and a/c. Can i use the factory compressor? will this unit clear the frame? will it work with vintage air? and if not,,who makes a relocation bracket(with factory or sanden compressor) ? as long as i am asking to many questions,,will the factory mounting of the p.str and alt. fit right into the chassis? i am a new memeber and this is my first ls1 swap. anything you guys can tell me would be so helpful. including vendors i can go to,,,thanks,,sickracer
  3. ErikNORCAL
    ErikNORCAL Veteran Member
    1,141
    12
    Aug 6, 2003
    now in VA
    Welcome to the best site! You should start a separate thread topic though in this section or maybe even one in projects of your car.
