Virus? Microsoft alert? With W10 OS?
Discussion in 'NastyZ28 Gamers & Computer Gurus' started by tom3, May 31, 2018.
  1. tom3
    tom3 Veteran Member
    12,081
    364
    Aug 1, 1999
    ohio
    Wife's desktop with Windows 10 doing some real strange things. Takes over the computer. Rebooted/refreshed to original config but saved files. Ran all the scans I could find. Still pops up. Are we doomed? Screen shots with camera. Help!
  2. Gary S
    22,639
    829
    Your computer has been hacked by ransomware. It has nothing to do with Microsoft. If you pay them money, they will unlock it (for a while).
    https://whocallsme.com/Phone-Number.aspx/8665880483
    If you are smart, you will format the disk, install a clean copy of Windows and start over.
  3. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    I wouldn't jump to that conclusion until I ran all root-kit scans.
    Have you done that?
    Here is some older info to look at:
    Read that page well. It gives you several options to use to get rid of it.
  4. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
  5. tom3
    tom3 Veteran Member
    12,081
    364
    Aug 1, 1999
    ohio
    Apparently Microsoft took care of it. I sent a message to the MS fix it site, got no answer but the problem went away the next day. Thanks for the tips!
  6. MoarThrottle
    MoarThrottle Veteran Member
    180
    12
    Aug 22, 2013
    Denver, CO
    You are not done by a longshot. Its highly recommended you at the very least install update and run anti-virus, anti-malware and then review the registry to see what is being ran at start up that you may not be aware of.
    Have you changed the passwords to important websites such as your bank from a secure machine that hasn't been compromised? You need to do that and then not access those websites on your pc until you KNOW for a fact it is clean.
    If you can't do the first paragraph then you should really re-format and re-install windows.
  7. Knuckle Dragger
    14,952
    1,419
    Nov 2, 2002
    Waddell AZ
    You're a little late to the party man, this thread is a year old.
  8. tom3
    tom3 Veteran Member
    12,081
    364
    Aug 1, 1999
    ohio
    Haven't seen that popup since. Either got lucky or MS did fix it.
  9. COPO
    18,010
    836
    All you needed to do was reboot your PC in safe mode and restore it to an earlier time/date and most likely got that msg from surfing porn sites.
    budro6968 likes this.
  10. mallard
    mallard Veteran Member
    598
    138
    Oct 3, 2013
    SK, Canada
    At least that's what you've been led to believe. :rolleyes:
