Vortec with TH350?
Discussion in 'High Tech Retrofits' started by 77LT94Z, Mar 4, 2006.
  1. 77LT94Z
    77LT94Z Veteran Member
    114
    Mar 24, 2004
    Cleveland, Texas, USA
    Hey guys, I have a 1976 LT with 350/TH350 in it right now. I have a 1998 Vortec 383 stroker that I want to pop in. The TH350 I have now is built, so I would really like to keep it. Will it be a very difficult proposition? Thanks Dwayne
  2. 77LT94Z
    114
    Mar 24, 2004
    Oh BTW, I have the vortec 4bbl intake, so it will remain carbed with an Edelbrock 750, Vortec performer heads with 1.6 rr's, Comp 270 magnum cam, speed pro hypereutectic pistons, melling double timing chain, Scat crank.
  3. 1978LT
    1978LT Veteran Member
    16,280
    Feb 24, 2002
    Poquoson, VA USA
    I'd say you can go to sleep each night with peace of mind ;) I have a stock 406, TFS heads, roller cam, and a TH350 built to stock specs other than a mild shift kit and it has held up very well!!:bowtie:
  4. 77LT94Z
    114
    Mar 24, 2004
    so, will the TH350 bolt right up to the Vortec?
  5. mike73z
    mike73z Veteran Member
    396
    May 20, 2005
    Burleson, Tx
    Yes it will. What are you waiting on put it in!
  6. 77LT94Z
    114
    Mar 24, 2004
    I still gotta paint and detail the engine bay first..the interior is done! The JL audio system is Done! The exterior is Done! the engine bay & motor are last things!!!!!!:)
  7. 77LT94Z
    114
    Mar 24, 2004
    here are the pix so far... what you think?
  8. BC's71'
    BC's71' Veteran Member
    1,125
    May 16, 2000
    North Chicago Suburbs
    Whoa, completely tinted out looks pretty slick on a black car!
    Looking good!
