Wanted 12 Bolt for 70 Firebird
Discussion in 'Swap Meet Section' started by Doright, Nov 22, 2019.
  1. Doright
    Doright New Member
    Nov 22, 2019
    Hello everyone first post
    I am building a 70 Firebird currently and looking for a 12 bolt rear that will bolt in and play.
    I do not care about matching numbers! or if it has a Posi or not I just need a fairly complete 12 Bolt that will bolt in to original leaf springs with original drum brakes. I Don't care if its greasy I don't care if it leaks! I don't care if its just a bare housing! although complete with axles and brakes is a big plus!
    Just something that will bolt in and bolt up I can throw a Carrier in it and gears at a latter date.
    I am in Pahrump Nv willing to drive a fair distance to pick it up.
    Dennis
    775 five3seven8fourfiveseven
  2. Gary S
    22,661
    835
    Those rear ends are a one year only rear end. They were used on '70 Firebirds and '70 Camaros only so there aren't a lot of them in existence. A bit of patience should find you one.
  3. Doright
    Doright New Member
    Nov 22, 2019
    I am hopping to find one, I am no realy hurry and I really don't wanna spend 2500+ for a custom built one.
    I have seen a few used ones advertised in about the same price range as a new custom built unit, if I have to spend nearly 2 grand for it I would buy a new custom built one from Mosor.
    Seriously though I thought they fit other models and years? if 70 is one year only for Camero and Firebird set up I may have to go the custom built rout.
  4. badazz81z28
    17,158
    558
    Las Vegas, NV
    If you don’t care about matching #s, spend the money on a Moser. You think it’s expensive now, but buy your $1500 12 bolt and pay to rebuild it, you have $2500 into it and it won’t be as good as a Moser
  5. Gary S
    22,661
    835
    By "one year only", I meant that they were made only in 1970 and available only on 1970 model cars. But, they will fit any 1970-81 Camaro or Firebird.
  6. 70-camaro
    70-camaro Veteran Member
    2,430
    488
    Mar 25, 2010
    marietta ohio
    And in 70 they were only available in the Z28 and SS cars. All other models had the 10 bolt. So it will be very hard to find one.
  7. badazz81z28
    17,158
    558
    Las Vegas, NV
    8.2 10 bolt at that...Also 70 only
    70-camaro likes this.
  8. Pc3
    Pc3 Veteran Member
    2,984
    Jul 6, 2000
    CT
    I have one in my 74 How soon do you need it. Its a posi with moser axels and 4.10 gears. only problem is car is at the body shop getting some work done . where you located
  9. Zspoiler
    Zspoiler Veteran Member
    3,312
    273
    May 6, 2012
    Federal Way, Washington
    As long as you have the cash .There are aftermarket ones built the way you want.
  10. Bikefixr
    Bikefixr Veteran Member Lifetime Gold Member
    1,790
    67
    Mar 13, 2006
    Wish you were closer. I have 2 of them. NJ is a hell of a drive.
