Wanted Early axle bump stop and bracket
Discussion in 'Swap Meet Section' started by 69venture, Oct 13, 2017.
  1. 69venture
    69venture Member
    30
    Nov 11, 2015
    Greenville SC
    I am in need of one early style 1972 rear axle bump stop and bracket. Sample picture below. I am missing 1.
    Let me know. Thanks
  2. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,225
    43
    Jan 1, 2005
    Schererville,In.46375
    I hard to tell by the picture...does these bolt on ?
  3. grzewnicki
    3,390
    149
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Yes they bolt on in the wheel wells. They changed bolt patters somewhere in the mid 70's for some stupid reason, probably the same time they changed the bolt pattern for the front wheel well support brackets, frickin GM engineers, what the hell good reason is there for changing a bolt pattern on a part that looks just like the old part????
  4. Ricks72Z28
    1,225
    43
    Jan 1, 2005
    I was talking about the rubber part.. The newer ones are secured with a nut.
  5. 74BIBELOT
    74BIBELOT Veteran Member
    865
    53
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    88845D6B-C4E3-468A-A940-9349BB7AC2FD.png CC2771F1-A791-47AD-9E54-69A3713340D9.png Just for reference:
    These are the 75-up bumper stops- different bolt pattern.
  6. 74BIBELOT
    865
    53
    Jan 19, 2006
  7. 69venture
    69venture Member
    30
    Nov 11, 2015
    Greenville SC
    Yes the bumper bolts to the bracket. The first versions had a bumper that pressed into a slot inthe bracket. Im not sure exacty when they went to a bolt on bumper but mine is an original 72 and the bumper is bolt on. I need a old style early bracket with the bolt on bumper.
  8. 69venture
    69venture Member
    30
    Nov 11, 2015
    Greenville SC
    This is what I have on my 72 and am in need of one more like it 664877C0-A1B4-4C9C-96B2-F147B278D823.jpeg A02D0287-C96B-4DD7-8D54-43DA8E7A4227.jpeg 6FAA755A-B3EB-4B98-9292-7B00DBB12450.jpeg
  9. Ricks72Z28
    1,225
    43
    Jan 1, 2005
    I have NOS ones.. Please e-mail me if interested.
  10. 69venture
    69venture Member
    30
    Nov 11, 2015
    Greenville SC
    I sent you a message here. Thanks
