Wear pattern
Discussion in 'Transmission & Driveline Topics' started by FlaJunkie, Nov 16, 2019.
  1. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    Yeah, I was just hoping! <sigh> I am getting way too old to do this floor work!
  2. big gear head
    big gear head Veteran Member
    6,187
    85
    Jul 30, 2001
    Central City, Ky.
    Yeah, I know what you mean. I'm only working on my own car now. After many years of doing gear swaps on my back I finally called it quits. It's a lot easier to tell others how to do it.
    77 cruiser likes this.
  3. Jeep43
    Jeep43 Veteran Member
    1,298
    48
    Mar 30, 1999
    Connecticut
    What are you doing? Installing new gears or just checking what you have been running?
  4. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    The idea was to try to reduce the backlash. We spent the time trying to figure out how to get the cross shaft back in. That was fun. Ended up having a thrust washer fall out and we couldn't get it back in. Big gear head gave me a suggestion, but we had already finished. I think the next time the case is opened, i need to change the clutch packs and do a seal overhaul.
  5. big gear head
    6,187
    85
    Jul 30, 2001
    Central City, Ky.
    Don't drive it without that thrust washer any farther than the shop where you will be fixing it.
  6. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    I just watched the two Tom's videos about rebuilding the Eaton...Damn! That is complicated.
    I also learned that we have WAY too much endplay in the axles...meaning the clutch packs must have 'narrowed' down a bit. I am getting TOO old for this!
  7. COPO
    17,867
    753
    Your never too old to work on a hot rod or muscle car. I’m 66 and feel like I’m 20.
    Dave Nelson likes this.
  8. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    I do. Anyway, I've found what appears to be a great place in Ormond Beach to do the work! December 9th, we start.
  9. big gear head
    6,187
    85
    Jul 30, 2001
    Central City, Ky.
    I was going to say that you could send me the Eaton and I would rebuild it for you, but if you have a local place then that will work better for you.
  10. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    I appreciate that. Talked to the owner for half and hour...he builds hot rods and has entered a 78 Camaro in the Daytona Road Races. He also mentioned replacing my exhaust with a more modern design. We will see next month.
