Weber Carbs?
Discussion in 'The BS Topic' started by wiseryder, Jun 14, 2018.
  1. wiseryder
    2,056
    40
    Sep 11, 2004
    belding,mi USA
    Hi guys, Im not sure where to put this so I it here.
    Im working on a jeep with a weber card, Ive never worked on these things before ,Im sure someone here has..
    The thing runs super rich , stinks bad of fuel , Does someone know anything about these carbs?
    Thanks
  2. Zspoiler
    Zspoiler Veteran Member
    2,912
    189
    May 6, 2012
    Federal Way, Washington
    Have you talked to Weber direct ?
  3. carr911
    carr911 Veteran Member
    1,306
    255
    Mar 4, 2016
    Tampa, FL
    I've worked on a bunch on older Porsches. There are a bunch of different jets - Porsches have problems with Idle Jets clogging.
    Probably going to need a Manual for that specific model
  4. Zspoiler
    2,912
    189
    May 6, 2012
    Have Weber send you a manual .And or there is a SAE book on Weber Carbs ,I have seen one on Amazon. That brand of books help me a lot when I started to work on cars in the 1970`s ,Before the net.
  5. cali cruzer
    cali cruzer Veteran Member
    2,732
    111
    Mar 24, 2002
    Henderson/Las Vegas, NV
    What kind of Weber? A 2 bbl like a DGV or?
