Weight difference between SBC and BBC?
Discussion in 'Engine Topic' started by NYH1, Sep 3, 2018.
  1. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    Central New Yorkistan
    What's the weight difference between a SBC with aluminum intake, iron heads, and iron water pump and a BBC with aluminum intake, aluminum heads, and aluminum water pump?
    Thanks, NYH1.
  2. dave@ztech
    3,616
    761
    Mar 27, 2016
    NY
    depends on who you ask, I would guess around 80-100 pounds
  3. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    Is that comparing them with all iron components (intake, heads and water pump)?
    Thanks, NYH1.
  4. dave@ztech
    3,616
    761
    Mar 27, 2016
    NY
    Generally the diff is considered 150-175 pounds , stock to stock, so you could guess that with the setup you mentioned, you would be in the 80-100 pound different
    NYH1 likes this.
  5. Zspoiler
    Zspoiler Veteran Member
    3,344
    276
    May 6, 2012
    Federal Way, Washington
    Then there are aluminum block versions on both sides.
  6. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    Thanks Dave.
    NYH1.
  7. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    No aluminum blocks for me....ain't got that kinda money!
    Thanks, NYH1.
  8. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    How much would that extra 80/100 lbs. effect the handling of a late model 2nd gen. Camaro? Doesn't seem like a lot of weight. I've never had a big block car though.
    Not that it matters, but I'm thinking about a 454/496.
    Thanks again, NYH1.
  9. xten
    xten Veteran Member
    3,176
    1,974
    Sep 24, 2014
    Pittsburgh, Pa.
    Put a rack and pinion set up in to enhance your driving pleasure and shed some of the excess weight of the BBC! It's a two-fer! lol
  10. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
