Weight difference between SBC and BBC?
Discussion in 'Engine Topic' started by NYH1, Sep 3, 2018.
  1. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    Central New Yorkistan
    Aren't standard, non-truck tall block, 396/402, 427, 454 and even 502 the same physical size on the outside? The all have a 9.800" deck height. Components can be used/swapped on all of them.
    NYH1.
  2. Chevyforever
    Chevyforever Veteran Member
    726
    98
    Jan 4, 2011
    I agree with NYH1 above post 100 %. I have been around/built/ owned and sold these engines for 40 years.
  3. Jon balch
    Jon balch Veteran Member Gold Member
    240
    76
    Mar 29, 2017
    Upstate NY
    B5B8BBDD-E5DB-481A-9724-A59E5E302D57.png You are correct sir. Even my dart 572 is a 9.8 deck height
  4. dave@ztech
    3,642
    762
    Mar 27, 2016
    NY
    Sorry, I thought I had read that the new tall deck BB was into the 10 something range, well nevermind, HAA HA , so much for reading retention !! HAA HA
  5. Randy 81
    Randy 81 Veteran Member
    933
    20
    Oct 28, 2009
    Loganville, Ga
    Well, the 8.1L deck height is in the 10 something range, maybe that is what you read. Not much of the 8.1 interchanges with the older BB though.
  6. John Wright
    14,716
    216
    Aug 9, 2002
    Rustburg, Va
    http://mooregoodink.com/rebirth-of-the-8-1l-vortec-and-advancement-of-merlin-iv/
    Goodwrench1965 and dave@ztech like this.
  7. Goodwrench1965
    Goodwrench1965 Veteran Member
    925
    41
    Apr 23, 2010
    Charlotte NC
    I guess the tall deck blocks at 10.2” required different intake manifold and or exhaust headers? Is that all? The 10.2 tall decks if I’m understanding correctly origin is the mark 4 BBC engines based on the 8.1 liters like were available in GM pickups? The accessorie drives on front of engine were different or were they same as the older 454-502 blocks?
  8. Randy 81
    933
    20
    Oct 28, 2009
    Loganville, Ga
    There are tall deck versions of the older Mark 4 and Gen 5/6 engines and then there is the 8.1L, which is out on its own. The accessory drives for the 8.1 are different than the older engines and don't work on them. Oil pans are wider and intakes are unique due to the intake port design, along with no coolant passages in the intake. Exhaust bolt pattern is the same as the other BBCs. Valve cover bolt pattern is the same, but 8.1 valve covers are shorter.
