Welder buying help!
Discussion in 'The BS Topic' started by 80sz, Sep 19, 2016.
  1. fester
    fester Veteran Member
    132
    9
    Jun 26, 2016
    Central Texas
    No matter what welder you use, you GOTTA keep the metal clean!! The grinder is your friend. Welding over dirt grease or slag is like trying to re-use a condom. Brush and dress your welds when completed. This allows you to see better what you need, more-less heat, more-less wire speed etc. Experiment with stick rod, that will allow you to learn to watch your puddle and improve your had eye co-ordination. Once you learn to control the feed and speed you can try your hand at TIG... Enjoy
  2. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    Yup, you'll like that one much better. I still have one of those from back when they were 135 Handlers. Been a great lil machine.
  3. BowHunter
    BowHunter Veteran Member Lifetime Gold Member
    960
    17
    Nov 12, 2004
    Wappapello Mo, USA
    Skip the harbor freight 220 1 Bought 1 and carried it back Sucked big time gat name brand Miller, Lincoln , Hobart ECT
  4. 80sz
    80sz Veteran Member
    3,216
    429
    Feb 2, 2014
    Buffalo,n.y.
    Thanks for the help. I have to read over manual tonight and tomorrow I'll be practicing ! And thx for tips ,I'll be looking for more,I got .030 flux wire in now that came with it. Saving now for the tanks,hopefully soon I can do some gmaw welding! Lol lingo:)
  5. mrdragster1970
    7,822
    507
    Apr 12, 2007
    FYI, I learned more in 5-10 minutes having my neighbor, an expert welder show me,
    then I did in 5 years of reading stuff online and manuals!!!!
    Practice, practice, practice!!!!!
    OH YEA, I have a Miller 250 TIG and Miller 250 MIG, Millers are awesome!!!!
  6. CasperCasper
    CasperCasper Veteran Member
    1,071
    176
    Aug 11, 2015
    Excellent choice OP, if you are doing any body work with this machine my tip is go painfully slow. I mean do a couple tiny tacks and let that panel cool down. Patience will do you well. Thats a sweet setup.
  7. perkalator
    perkalator Veteran Member
    1,025
    90
    Aug 27, 2014
    kennewick wa
    You got the better machine. Stay away from the store brand lincolns. Plastic drive gears and spools for the wire feed.
  8. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    The Hobart 140 is a GREAT welder. Returning the lincoln and getting the Hobart 140 was a wise thing. I have had mine for close to 12 years now and not a single prob out of it.
    Get shielding gas for it and use solid wire and gas on all of your welding. Much cleaner welds.
    I buy the larger 10 lb spools of wire, and I bought a 140 cu. ft gas bottle. I find it just easier to deal with and I hate running out of wire or gas in middle of a project.
    Use .023" wire on body panels, sheet metal. Use .030" on just about everything else.
    I have welded frames, roll cage, car hauler ramps, go carts, brackets, sheet metal, exhaust, etc with mine over the years. In fact I just finished building a mobile keyboard, power supply, amp cart for the local high school marching band.
    The claims on metal thickness for welders, plasma cutters, etc is BS for the most part. A good rule of thumb is for a single pass MIG weld you need 1 amp output per .001" thickness steel you are welding. IE... 1/8" steel is .125" you need 125 amp.
    I have welded 3/16" (car hauler ramps) steel with my Hobart 140 but I double and triple pass welds on it.
    I would never try to weld 1/4" steel with a 140 amp mig.
    Practice and clean metal is the best 2 things to keep in mind. Keep a couple of angle grinders handy with grinding wheel in one and wire cup in another. You want clean shiny metal to weld to.
    Also if you are butting 2 flats together to weld, you want to bevel the edges some.
    Practice on thicker steel at 1st to get use to it (less risk of blowing a hole in it) when you get the hang of it some then go to the thinner steel.
    Watch some welding Youtube vids. I like chucky2009, he's fun to watch and gives pretty good info.
  9. 80sz
    80sz Veteran Member
    3,216
    429
    Feb 2, 2014
    Buffalo,n.y.
    I'll be in training tonight after work, got a friend who can weld helping me out. Then of course he wants to borrow it,man already I just got it!
  10. My73LT
    My73LT Veteran Member
    1,540
    May 29, 2001
    Orlando, Fla
    You'll be happy with that one.
