Welding door gaps
Discussion in 'Body Restoration' started by woody80z28, Oct 4, 2015.
  1. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    So the new Goodmark skins are terrible...and there are some gaps to weld. Got one done, but here's my question:
    What is the best way to finish the seam where the skin is folded over?
    Welding melted the seam sealer that was in there. Now I can dig out what was sealed on the visible part of the seam on the interior part of the door, but what about the sealer that was between the door shell and the skin? Just try to seal it from inside the door guts? Makes me kinda sad because it all looked beautiful with fresh epoxy and sealer...haha
    What have you done?
  2. Scott51
    Scott51 Veteran Member
    622
    69
    Jan 2, 2012
    New Zealand
    pretty sure they only applied sealer/caulking to the outside of the join but could be wrong.
    Anyway if it was me I'd squirt some cavity wax or fisholene in there and every other crevice once paint is done.
  3. bodymanbill
    bodymanbill Veteran Member
    1,262
    616
    Feb 1, 2007
    South Park Pa
    I second the cavity wax i use it on all the panels i replace. this is the stuff i use[​IMG]
  4. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I taped both edges and made a "channel" to apply the seam sealer. After applying it with a caulking gun or acid brush, dip your finger in some lacquer thinner and smooth it out for a really nice smooth finish.
  5. earlysecond
    earlysecond Veteran Member
    5,618
    Aug 9, 2002
    Altoona, PA
    Hey Woody,
    I did what you did by building weld. After the fact, which i would have used 1/8" rod instead. Less heat, easier to shape.
    You'll be fine if you reseal the visible stuff on the outside. Do what Aaron said for process and it will turn out fine.
    Brent
  6. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    Yeah, I saw the 1/8" rod trick in Car Craft like 2 days after I got it done.
    The visible stuff is easy, that's not a problem. I'm not sure if I'd rather do cavity wax or a bead of sealer on the inside part. I was already planning on doing some sealer at the bottom edge of the door on the inside. Maybe it would be good to just continue it up the door edge. I'm sure I can't spray the cavity wax and seal it up...
  7. Z28zz383
    Z28zz383 Veteran Member
    811
    11
    May 11, 2012
    Florida
    My original factory doors have a gap problem in the same area as where you added metal. Plan on fixing them next paint job.
  8. Scott51
    622
    69
    Jan 2, 2012
    New Zealand
    seam sealer on the outside using the technique Aaron described, cavity wax or fisholene on the inside.
    The good thing about cavity wax type products is they don't require the kind of prep that paint and sealer products do and they're designed to creep into all the places you can't get to.
    Just blast/vaccuum out any dust and crud you can, check all your drainage holes are clear and apply liberally (after paint of course) It'll drip out for a day after but can be wiped off easily without damaging anything. Should be considered a necessary step of any paint job and a good idea for anyone trying to preserve and old car.
  9. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    I don't have one either but this is a job for a Tig. The 1/8 rod an a Tig would of been perfect. So once you grind that smooth what are you going to use as a filler for all of those small pits? Lead? JB Weld? Both of these work real well if you can keep it from running out of the pits.
    One thing I used instade of seam sealer was Loctite Polyseamseal ( clear) Yes its the stuff you would use on bath room tile. It is an adhesive. Its paintable once it been on for a few hours. Its flexable. Its a hell of a lot easier to apply than seam sealer. I've had it on my Camaro for a few years now, has not failed. Comes in a squeez tube, bought it at Lowes.
  10. xten
    xten Veteran Member
    2,799
    1,553
    Sep 24, 2014
    Pittsburgh, Pa.
    Same stuff I use. Works great. It's runny enough to get in all the crevasses then turns to wax.
