Welding door gaps
Discussion in 'Body Restoration' started by woody80z28, Oct 4, 2015.
  1. earlysecond
    earlysecond Veteran Member
    5,618
    Aug 9, 2002
    Altoona, PA
    I sold in the aftermarket right out of college. THAT lookss like a really old Rubber Seal can! Prolly stillngood though!
  2. bodymanbill
    bodymanbill Veteran Member
    1,262
    616
    Feb 1, 2007
    South Park Pa
    Actually Its only a couple months old. I go through a can of it probably every two months at the shop
  3. earlysecond
    5,618
    Aug 9, 2002
    Altoona, PA
    Bill,
    Wow! They must have never changed labels then haha!
  4. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    Now you have me wondering if cavity wax would be better for the bottom edge of the door as well. Everything was blasted, epoxied and then assembled so I'm not really worried about the prep for that part.
    Am I correct in thinking that seam sealer is more permanent than cavity wax as long as the prep is good?
  5. Double R Restorations
    2,549
    31
    Jan 11, 2002
    An idea that was given to me was taping the folded edge and filling the inside with some epoxy.
  6. earlysecond
    5,618
    Aug 9, 2002
    Altoona, PA
    What did the factory do? I like over -engineering stuff. Maybe im not clear on what you are asking?
  7. Scott51
    Scott51 Veteran Member
    623
    69
    Jan 2, 2012
    New Zealand
    the problem with these kind of solutions is the inability to properly prep inaccessible areas so once adhesion fails or you get cracking from movement the product just becomes a moisture trap.
    Also even a heavily reduced paint won't have viscosity comparable to most cavity waxes or fish oil products - the idea is to seep and creep, in a good way.
  8. Scott51
    623
    69
    Jan 2, 2012
    New Zealand
    looks like you did a great job priming everything before assembly so are already way ahead of the what the factory did and just need to keep moisture out and prevent rust starting on any areas that you've burnt off paint from welding.
    Don't know if I'd say seam sealer is more permanent they're really two different products for two different applications. Seam sealer for keeping moisture out (buy yeah proper prep is necessary) and cavity wax or fish oil for preventing rust.
    Even if you could prep the inside of the lap joints to apply seam sealer it's not going to creep into the flange so I'd be worried about creating a potential air/moisture trap for the inaccessible areas effected by welding to start rusting.
  9. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    I think the best game plan would be to cavity wax the seams that have been welded and hit them with a rag soaked it brake clean or something to clean off the accessible areas for the seam sealer to adhere.
    In theory that way the cavity wax stays in the bare metal (burned epoxy) area and you can seal off any moisture from getting in.
    Anyone tried something similar?
  10. jimbaughan
    jimbaughan Veteran Member
    310
    Sep 1, 2007
    meansville,ga
    I put my skins on with door skin adhesive. After hammering the edges flat I just wiped off what oozed out. No chance for water to ever get between the panels.
