Welding door gaps
Discussion in 'Body Restoration' started by woody80z28, Oct 4, 2015.
  1. xten
    xten Veteran Member
    2,885
    1,645
    Sep 24, 2014
    Pittsburgh, Pa.
    Or you could just spray some epoxy primer in there till it runs out the bottom. Then cavity wax it and you'll never have anything to worry about.
  2. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    Epoxy shrinks over time. I've seen that in my mixing cup. Would not be a good way to do it. I'm hoping I can get seam sealer to stick after cavity waxing that little bit where the epoxy has been burned off.
  3. xten
    xten Veteran Member
    2,885
    1,645
    Sep 24, 2014
    Pittsburgh, Pa.
    Yep, so does every other primer, base, clear and single stage. I see it in mixing cups for all of them every day. I have done this countless times without issue. As long as you don't leave any bare metal exposed, you'll be fine.
  4. Double R Restorations
    2,550
    31
    Jan 11, 2002
    Yes this repair would only work where the skin is being replaced, therefore you would prep the shell prior to the skin being installed. I like the idea of using cavity wax also.
