What’s left of my build sheet
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by DessertRat, Mar 11, 2019.
  1. DessertRat
    DessertRat New Member
    15
    Sep 3, 2018
    5E02108B-9769-4384-AC10-F989BCF5D32D.jpeg 5137B4E8-DF05-4CAE-9BB8-201F1D31BC84.jpeg 5E859E85-1FFB-4F8D-9E16-A14450C1D0DF.jpeg 996B88F8-832E-4CE2-BB68-69171A0D4D29.jpeg ACDCEDA1-2035-42E3-BDFB-62EACB71FBE7.jpeg 8DE8C2F9-07E0-4D70-A51B-0759C3EA0738.jpeg 6FC73C9F-32FA-49C2-9E53-542446EAF164.jpeg C2769773-6FA5-430C-92E1-8CE15C12114F.jpeg 36DDF408-97AD-4DCE-A3BD-71FB2BEC1C91.jpeg B1938D7B-3891-4765-AA48-33F31D016033.jpeg
    Found the build sheet and I’d like to know where I can find out what some of the codes mean. Comparing this one to pictures of others I’ve seen on the internet, it looks like it’s missing a lot of the important codes from the lower right side. The car is a 1971 LS3 4 speed. Thanks -Vinnie
    70ZED likes this.
  2. DessertRat
    15
    Sep 3, 2018
    Thanks for the info on the links. I was curious with box #25. It says " spec. ord " and has a ZC in the box. Does anyone know what that one means? I couldn't find it on the list of codes.
  3. 70 SS/L78
    2,590
    64
    May 5, 2005
    Rockford, MN
    Not sure what that means off-hand. I have electronic copies of other buildsheets but they are all from 1970. Somewhere I think I have 1 from 1971 on another computer.
    No doubt the build sheet does confirm it's a LS3 4-speed car, so that's a huge bonus! Nice find!
  4. ronzz572
    1,914
    51
    Feb 8, 2007
    imperial pa
    I would also look above the gas tank and under the seat upholstery between the foam. Vannuys built camaros are known to have more than one build sheet. Nice score finding and having a build sheet confirming the car a big block.
