What bulb for glove box light Type LT?
Discussion in 'Troubleshooting & Diagnosis' started by bondora68, Jan 16, 2020 at 10:54 AM.
  1. bondora68
    bondora68 New Member
    Dec 14, 2014
    Mobile, AL
    Hello, I have a 1975 Type LT with the special glove box light located in the top center of the glove box with the little plastic lens...No matter what bulb I try in that little light nothing happens so I need to make sure that I have the correct bulb before I go playing with the wiring. I tried one of those little slide in bulbs that works for the instrument panel (new) with no luck. I used a test light to detect 12v at the light...I also bypassed the switch and wired straight to ground but still no light..
  2. Z28SSRS
    Z28SSRS Veteran Member
    162
    15
    May 2, 2009
    Nevada City, CA
    I am guessing your 1975 would use the same bulb # as my 1978. My owner's manual lists a 189 or 194 being the correct bulb.
  3. BillyDean7173
    BillyDean7173 Veteran Member
    1,624
    323
    May 21, 2014
    Hutto, TX
    Sounds like something is wrong with the contacts in the socket causing the bulb not to make a connection.
    EDIT: Or perhaps the wiring going to the contacts inside of the socket. Not to insult you, but have you checked for continuity?
  4. bondora68
    Dec 14, 2014
    Mobile, AL
    I'll test for continuity on the ground side...
    thanks guys!
