What cars did some decent turbochargers get put in.
Discussion in 'High Tech Retrofits' started by Kasey74, Mar 18, 2007.
  1. Kasey74
    Kasey74 Veteran Member Lifetime Gold Member
    1,143
    Oct 7, 2002
    Calgary, Alberta, Canada
    If i was going to go to a wrecking yard and look for a turbo to rebuild, to play around with on a 350, which cars had the "good" turbo's / wastegate's, etc, on them. I have an old truck that i was going to build a turbo system for, just to experiment, and was wondering if i should use a small turbo, large one, or one of each, and do a twin setup to get boost right across the rpm range... don't need to run much boost - yet. The cheaper, the better --- in this case, anyway.
  2. ZedMan
    ZedMan Veteran Member
    178
    Dec 15, 2004
    Calgary, AB, CA
  3. Kasey74
    1,143
    Oct 7, 2002
    ...cool, thanks.
  4. LTjames
    LTjames Veteran Member
    1,157
    May 12, 2005
    La CaƱada, CA, USA
    I have a Rajay 301E10 (T04B..) on my 78 and it supposedly supports 425 hp. Turbomustangs.com is a great place to ask these questions, very knowledgeable people over there.
  5. Kasey74
    1,143
    Oct 7, 2002
    Anybody have specs / pics / diagrahms of a turbo system they have built ?
  6. chevroletcamaro
    chevroletcamaro Veteran Member
    267
    Apr 8, 2006
    Sevierville,TN
    I kinda like the 14B and 13G of the 1st gen eclispe/talon. Now i dont know an awful lot about turbo scienceness, but if a turbo off a 4 banger can push 14-16 lbs of boost to a 2.0 motor, then couldnt the 4 banger turbo push 6-7 lbs of boost to a 5.7? Plus they were pretty cheap on ebay the last i looked, around something like $45.
  7. Kasey74
    1,143
    Oct 7, 2002
    thanks....again:crazy:
  8. craggar
    craggar Veteran Member
    5,769
    Jul 28, 1999
    edmonton
    I'm doing a twin setup on my Vega right now. There's a post in the comp. section with some pictures.
    http://www.nastyz28.com/forum/showthread.php?t=79703&page=3
    The kit less the plumbing was for a 3rd gen Camaro and bought off Ebay.
    Similar size to the turbo LTjames is using but 2.
  9. tom3
    tom3 Veteran Member
    12,224
    412
    Aug 1, 1999
    ohio
    About the only V8 car with a turbo was the Firebird as far as I can remember. That would be a pretty rare car to find in a boneyard. I remember JC Whitney had a turbo setup for the small block years ago that was pretty reasonable, would be a good way to go today if it was still available I suspect.
  10. Kasey74
    1,143
    Oct 7, 2002
    ... "roughly", would you know the cost on trying to do a setup like this. I have all the welding and tubing covered, ...just wondered on the cost of the "turbo" parts...
