What cars did some decent turbochargers get put in.
Discussion in 'High Tech Retrofits' started by Kasey74, Mar 18, 2007.
  1. Kasey74
    Kasey74 Veteran Member Lifetime Gold Member
    1,143
    Oct 7, 2002
    Calgary, Alberta, Canada
  2. Kasey74
    1,143
    Oct 7, 2002
  3. Twisted_Metal
    27,312
    1,123
    The Type R nitro funny car is unreal!!!!
  4. Kasey74
    1,143
    Oct 7, 2002
    Found some interesting sites on Turbo Manufacturer specs
    http://www.mhi.co.jp/en/products/detail/turbocharger_specification.html
    Mitsubishi Specifications
    Model TD02 TD025 TD03 TD04 TD05 TD06 TD07 TD08
    Organization output (PS) 8-40 12-56 15-65 22-100 40-130 60-180 100-130 150-450
    Amount of exhaust(cc) Diesel organization 600 1,000 1,200 1,800 2,300 4,000 6,000 10,000
    Gasoline organization Passenger car 500 750 1,000 1,500 2,000 2,600 - -
    Two-wheeled vehicle 250 400 500 750 1,000 1,300 - -
    The highest rotation speed (rpm) 270,000 250,000 230,000 200,000 170,000 145,000 132,000 114,000
    Temperature of gas allowance and the highest (Centigrade) 900 900 900 900 900 900 760 760
    The maximum compression ratio 2.2 2.2 2.3 2.4 2.6 2.7 2.8 3.1
    Weight (kg)
    - - 3.0 3.5 4.0 5.0 9.0 10.5
    With waist gate valve 2.0 2.3 3.5 4.0 5.0 6.5 - -
    IHI turbos
    http://www.ihi-turbo.com/turbo_RHE-RHF.htm
    Garrett turbo spec
    http://www.turbobygarrett.com/turbobygarrett/
    Some of the smaller size turbo's for lawnmowers,
    karts, barstools, etc.
    ...some of these sel for as low
    as $40 bucks on ebay, etc
    -mitsubishi TD015, ... TD02
    -IHI RHB31
    -Garrett GT1241
    -Mitsubishi 49133-01130 TD015R
    -Mitsubishi TD04-9b
  5. dcozzi
    dcozzi Veteran Member
    3,276
    524
    May 1, 2002
    Phoenix, AZ
    Not to be a downer but, no one mentioned doing any math to make sure what you are doing will be even close to working or working the way you want/need it to.
    This a good site to start on. They used to have a step by step with equations to arrive at the proper turbo(s) for what you are looking to do. It has about 4 pages of handwritten math but, you know what you are getting into. I felt educated and, at the same time, completely ignorant at the end but at least I had a plan.
    http://turbobygarrett.com/turbobygarrett/
  6. Kasey74
    1,143
    Oct 7, 2002
    You mean turbo maps ?
    I've found copying what someone else has
    allready been successful with the easiest method ?
    Hot Rod mag online, etc, have some good write-ups of
    low buck turbo installs, that work pretty decent
