What colour should I paint my trunk floor...?
Discussion in 'Body Restoration' started by The Seer, Oct 2, 2015.
  1. Twisted_Metal
    26,949
    931
    A thin coat of rattle-can satin black will be close to the factory finish.
    Trunk interiors were not body color.
  2. DavidH
    DavidH Member
    74
    Aug 5, 2014
    Kitchener,Ontario, CANADA
    My 80Z28 trunk floor is/was black, body color is/was Bright Blue
  3. earlysecond
    earlysecond Veteran Member
    5,618
    Aug 9, 2002
    Altoona, PA
    Its expensive and overkill but if you only want to donit once and have the tools. . .black epoxy primer then a quality truck bedliner was my choice. I use my trunk though, others may not.
  4. The Seer
    The Seer Veteran Member
    489
    Nov 1, 2014
    Essex England
    Thanks for the info there :)
    So, trunk interiors originally were more or less a satin black then?
  5. The Seer
    489
    Nov 1, 2014
    Essex England
    I can see how a truck bedliner would work for a trunk that's used frequently. Sadly for us here in England the price of fuel at $8.50 a gallon means we probably don't use these cars maybe as much as we'd like.
  6. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    The factory look is a three color splatter paint. My 77 was blue white and black from what i can tell the primary colors where blue and white.
  7. grzewnicki
    3,342
    123
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I used Raptor bed liner in my trunk, the kit came with 4 quart cans so I also shot the wheel wells and the battery tray and part of the fender well under the battery tray to cover some repair work where corrosion had been caused by a battery.
  8. paintman65
    paintman65 Veteran Member
    181
    9
    Jan 8, 2012
    Brenham TX
    My black '81 is black with a fine texture almost like undercoat. It's an LA built car if that makes any difference.
  9. Twisted_Metal
    26,949
    931
    Only on the later 2nd gens. Early ones had splatter paint in the trunks.
    I don't know what year they stopped using splatter paint but my 80 never had it.
  10. The Seer
    489
    Nov 1, 2014
    Essex England
    Mine came from the Van Nuys plant too. Thanks for the information :) I guess the undercoat has satin look to it.
