What engine is best
Discussion in 'Engine Topic' started by Thomas Mihalyi, Mar 24, 2020.
  1. BonzoHansen
    19,621
    891
    Jun 1, 2005
    Scott from Hamilton, NJ
    Or grab a sbc deal from someone changing plans. i just saw this today, i see stuff like this all the time. Just an example, but if budget matters and the car is already setup for a sbc that's not bad.
  2. tom3
    tom3 Veteran Member
    12,224
    412
    Aug 1, 1999
    ohio
    How about this for fun. Buy a generic 350 crate engine, put your 305 heads on it, a set of 1.6 : 1 rocker arms, free up the exhaust some, use every thing else already on your engine since it should be bolt on swaps. Last time I looked a 350 crate delivered was right at $1500, $100 or less for rocker arms, $50 for gaskets. Lots of bolt twisting. Make a real tire smoker with that. As money comes along you can build from this using that basic short block.
    mjgord51 and Zstar like this.
  3. Zspoiler
    Zspoiler Veteran Member
    3,344
    276
    May 6, 2012
    Federal Way, Washington
    A lot is what you want to do with the car and your budget .If want to keep it a small block and its easier to swap in another one .A used and or crate engine are a couple of choices that way.
  4. 73 Z
    982
    31
    Jun 9, 2007
    Los Angeles, Ca
    With the budget said, for quick up grade would be a rear gear change
    mjgord51 likes this.
  5. badazz81z28
    17,340
    596
    Alabama
    Gosh you could get 350 cheaper than a gear a change. Crazy...I can't believe what people charge for 2nd gen rears now.
  6. tom3
    tom3 Veteran Member
    12,224
    412
    Aug 1, 1999
    ohio
    I was wondering myself what the gear may be in the late Z28 auto. I'd think with that 305 it would not be a 2:73? More like a 3:23 or so? But I'd look into that on down the road a bit.
  7. badazz81z28
    17,340
    596
    Alabama
    A late year Z28 like a 1981 would have a 3.42. In a little older, the manuals got 3.73s while autos got 3.42
  8. BonzoHansen
    19,621
    891
    Jun 1, 2005
    Maybe the OP will chime in again lol
    dave@ztech likes this.
  9. mjgord51
    mjgord51 New Member
    15
    Jan 19, 2019
    SoCal. Lower Desert
    I think hes one of them ONE HIT WONDERS, could be wrong though....nah.. Was plenty of good answers.
  10. 1980RS
    1980RS Veteran Member
    3,668
    697
    Jun 17, 2006
    MN
    I was talking about the earlier 5.3 heads. Yes the 799's and 243's were used later and are indeed a good head but still belong on a 5.7, sure would like to test a set of either of them ported on a 6.0 or 6.2 bet they would make some impressive torque numbers with the smaller runners.
