What Engine to go with?
Discussion in 'Engine Topic' started by Shannon Lozinski, Sep 10, 2019.
Tags:
  1. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
  2. ErikNORCAL
    ErikNORCAL Veteran Member
    1,104
    9
    Aug 6, 2003
    now in VA
    L31R replacement. Transfer your oil pan, get correct intake manifold.
  3. tom3
    tom3 Veteran Member
    11,917
    327
    Aug 1, 1999
    ohio
    If I'm spending serious money on a crate engine it will have a roller cam and modern design heads.
  4. Notalent
    Notalent Veteran Member
    493
    Jan 27, 2010
    Dallas/LBC
  5. biker
    biker Veteran Member
    811
    64
    Dec 7, 2014
    New Liskeard Ontario Canada
  6. CorkyE
    10,266
    430
    AFAIK, they're using ATK/Profiler heads now. They used Dart's for a while, and a call to ATK would clarify the issue.
    Good to see you back Brandon, thought you were AWOL. :)
    Just a side note, I put an Edelbrock ProFlo 4 on my ATK 385, it's a whole new world.
  7. biker
    811
    64
    Dec 7, 2014
    Ok, must be a link to an older ad for the engine.
    Hi Brandon, just so you know, 3rd summer on my ATK SB64195 heads, running like a champ. 6500 rpm every day with a 530 lift roller cam, and no float from the springs.
  8. manicmechanic
    manicmechanic Veteran Member Lifetime Gold Member
    2,117
    Oct 24, 2000
    Tulsa, Oklahoma
    I have an 80Z with 104K on it. The Original block but Vortec heads and punched .040 and a Stroker kit (388 Ci) with a 2004R 4 speed auto and Original 3.42 rear. Don't go with anything Flat tappet (which is why I'm .040 instead of .030) 2 cams trashed in less than a year, first lasted 12 months and 2nd lasted 1 month and took a piston with it. This was when they changed the oil formulation and didn't tell anyone. I went Hyd roller so that's no longer an issue. With the 4 speed auto you might want to bump to 3:73.1 as the 3.42 does 1500 @ 45 mph in 4th with 275/50-15's. Running Heddman shorty's now but started trying to stay stock with exhaust and Air pump but when the state discontinued inspections I went past that.
  9. Notalent
    493
    Jan 27, 2010
    Dallas/LBC
    Hey Brent,
    We were, but Pro-Filer left us hanging and caused us to lose a substantial amount of $ not being able to fill orders over a year old. Had to part ways.
  10. Notalent
    493
    Jan 27, 2010
    Dallas/LBC
    Nice to be back, its been crazy here building a new shop and a new operating system that had the code break on launch....what a nightmare! Its still crazy, but we have got over most of the big hurdles and are settled in the new building now. Lots of big things to come :bowtie:
    I bet! The EFI kits make a heck of a difference. Smoother fuel maps, less smells, better throttle response and mpg....definitely a win there.
