What is "hardener" in paint for?
Discussion in 'Body Restoration' started by Cardinal, Nov 13, 2011.
  1. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    I'm not sure exactly what he was thinking either. JD and this "friend" spent HOURs block sanding it, 40 man hours just to get the Unlimited Products fiberglass hood to fit, put new front fenders on it, etc. just to urinate it away by not putting the hardener in the paint gun????
    I was LIVID when I found out! And the "friend" is a good body man (I've seen his work and he is very good) BUT I was flabergasted when JD told me that the "friend" didn't put the hardener in. JD was going to be there when he painted it but he had to work late that night so he wasn't there.
    JD and I CANNOT paint vehicles. We have NO patience and don't have the "eye" or feel for body work or paint application. I bow down to all of you who are body workers and painters.
  2. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    If he was using cheap old school acrylic enamel, technically hardener is optional, unlike cross-linking modern urethane paints. However if he used acrylic enamel that would point it out as being a bottom of the barrel grade respray job and then I'd still be very angry...
  3. dcozzi
    dcozzi Veteran Member
    2,955
    335
    May 1, 2002
    Phoenix, AZ
    That's the thing that confused me about him "using it later".
    Maybe he did not know how to use a disposable plastic measuring cup or what the ratios were.
    Friend:rolleyes:
  4. flowjoe
    7,976
    29
    Feb 7, 2006
    SoCal
    I was going to say that...something like Dupont's Centarri would not "need" hardener...while it is old school now, back in the day it was used for high end paint jobs (just as lacquer was). Before striping it all off I'd find out for sure what paint was used. If it was an acrylic enamel then maybe this paint job could be "saved" in the short term to save up to repaint down the road.
    If I'm reading this post correctly then the paints been on for 5 years...why the heartburn now? I would have thought that this issue would have been dealt with long ago.
  5. toadyoty
    toadyoty Veteran Member
    185
    Feb 21, 2011
    Stanwood, WA
  6. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    As for the "heartburn" after five years, it takes that long for me to come to a boil about some things! LOL!
    Actualy, JD and I were talking about his '83 S10 and what he wanted to do to it once he graduates from college. The first thing he wanted to do was to re-do the paint as it ticked him off that it chips so easily. It has been THEE one sore spot about his Blue Beast that has bugged both of us to no end. Every time the paint chips (for whatever reason) it opens up an old wound that just won't get better.
    That and I never got a difinitive answer to why it chips so easily.
    Here is a picture of JD standing by his Blue Beast III shortly after we got it home from being painted:
  7. earlysecond
    earlysecond Veteran Member
    5,618
    Aug 9, 2002
    Altoona, PA
    Ok so even if the hardener was optional. . .it was PAID for. I hope that he was not using enamel paint.
    Again, sorry this happened. As to why it chips easily. . .could be about anything. You would think that soft paint could not chip. Unless I am way off base, one reason that this could happen (there are many so this is speculation) is non-compatible substrates. In other words, if short cuts were taken and old school supplies were used, what is under that crappy top coat? Lacquer Primer? Who knows.
    In order to put a great paint job on that truck the old junk needs to come off. I just cannot see it any other way. Especially since there may be adhesion issues.
    Again, sorry but it has already been said.
  8. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    Not half as sorry as I am! LOL!
    I too wonder about the "substrate" (primer). I am pretty sure that they stripped the truck down to bare metal as JD talked about the time they spent doing that. BUT I do NOT know what primer our paint (for that matter) that they used.
  9. wookie
    wookie Veteran Member Lifetime Gold Member
    3,037
    Jul 12, 2006
    Daytona Florida
    Too bad you didn't live closer...
  10. LtRsZ
    LtRsZ Veteran Member
    902
    Apr 12, 2010
    Tacoma, WA
    Is that a real pic? He looks a little small next to the truck. Maybe it's the angle?
