What is this sensor?
Discussion in 'High Tech Retrofits' started by GDSmith, Feb 15, 2020.
  1. GDSmith
    GDSmith Veteran Member
    150
    26
    Aug 4, 2012
    Glen Ellyn, IL
    Can someone please tell me what this sensor is? Engine is from a LS2 from a 2006 GTO and this sensor is on the valley pan behind the intake manifold.
    Thanks in advance!
  2. bazookatooths
    bazookatooths Member
    37
    Apr 25, 2018
    OKC OK
    Looks like Oil Pressure
  3. biker
    biker Veteran Member
    1,170
    159
    Dec 7, 2014
    New Liskeard Ontario Canada
    Yes. Oil pressure. Change it now while you can actually see it. It's a bi@#% otherwise. Even if that one is good, it will need changing at some point. Keep that guy fir a spare.
  4. Knuckle Dragger
    15,171
    1,650
    Nov 2, 2002
    Waddell AZ
    Definitely oil pressure. Some have a screen under them that should be cleaned when changing it. There are two types of those sensors, one that failed and one that's about to fail. Throw the old one in the trash. :)
  5. bazookatooths
    37
    Apr 25, 2018
    OKC OK
    You guys are scaring me now I didn't change mine, but luckily I put a mechanical in the front oil galley plug lol.
  6. badazz81z28
    17,396
    604
    Alabama
    Ahh, don’t sweat it. If it’s not bad, it’s fine. Do you change light bulbs because they might not turn on the next time you flip the switch? That’s just crazy.
    Is this an LS swap? It’s not hard to get to in a sec gen.
  7. GDSmith
    150
    26
    Aug 4, 2012
    Glen Ellyn, IL
    I have another sensor right above the oil filter, was under the impression that is the oil pressure sensor???
  8. Knuckle Dragger
    15,171
    1,650
    Nov 2, 2002
    Waddell AZ
    That's going to be for an aftermarket gauge. I did my instruments the same way. The first one you showed was for the ECM. Depending on your programing/ wiring you may not need it.
  9. GDSmith
    150
    26
    Aug 4, 2012
    Glen Ellyn, IL
    Great, I have a Dakota dash so it makes sense now. Any harm pulling it and installing a plug?
  10. bazookatooths
    37
    Apr 25, 2018
    OKC OK
    I actually went with that logic on my crankshaft sensor, turned out the new one was defective and just put the old one back on that was a PITA!
    Heres another location for oil that I did on mine.
