What is this?
Discussion in 'Body Restoration' started by JOEY72camaro, Nov 2, 2019.
  1. hubedobeedo
    hubedobeedo 3rd times a charm
    429
    131
    Jul 18, 2013
    Huntertown,IN
    i reused mine included a Toyota charcoal canister in the back instead of the one GM put in engine compartment. yea i got alot going on back there but have good clearance on everything.used stainless tubing and the hose is multi fuel use the fuel is all hard line except for flex double stainless multi fuel all an fittings 3/8 feed 5/16 return. carter hv pump,4601. find out next year ? need for 500 hp under hood? if it breaks i will fix good times
