What LS Swap Radiator to use?
Discussion in 'High Tech Retrofits' started by ChrisK, Jun 5, 2019.
  1. ChrisK
    ChrisK Member
    39
    Jul 9, 2008
    Northbrook, Illinois
    What radiator is commonly used for a LS swap that has the connection for the steam tube?
    Thanks...
  2. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,389
    83
    Feb 2, 2008
    SF
    I used the stock 2002 camaro and on the next swap I’m using a 70 camaro big bock radiator with ls 1 fans and still working on the trans lines so yeah ....
  3. badazz81z28
    17,143
    555
    Las Vegas, NV
    I have a Dewitt LS swap radiator. It will be for sale soon as I’m moving up to a C&R
  4. Goat
    1,911
    44
    Jun 7, 2001
    moncure, NC
    If you have the $ to spend, C&R RACING!
  5. badazz81z28
    17,143
    555
    Las Vegas, NV
    Once you swallow the $1800 pill, you recover quick lol. If you want a radiator without extra coolers, you want to look elsewhere as C&R is a little expensive. Plus the fill cap is on the driver side preventing the use of a stock coolant reservoir and the design prevents using the Stock top plate. There are much more affordable options. You can have a Dewitt for half that.
  6. 75Maro
    75Maro Veteran Member
    435
    18
    Mar 31, 2008
    Dallas,Tx
    I used the stock 2nd gen radiator. Modified the upper rad hose from an 05 express van and used a gates lower hose. Do some research here on the gates hose I apologize I dont remember the part number. For the steam vent I used an inline drain valve in the upper radiator hose. - https://www.summitracing.com/tx/par...6itZbqvVZN_qhvGENNa9xd2qXCmaveQFfkaAuHf8P8HAQ
    Just swapped the drain "cock" for a barbed fitting and attached the steam line to that.
  7. badazz81z28
    17,143
    555
    Las Vegas, NV
    ^ I personally did this on my first LS swap, but it’s a pain and ugly to route a hose from the driver side all the way to the passenger side. If you keep the stock radiator try to use the newer LS3 pump where the pump inlet is more towards the driver side.
  8. Pierre74LT
    Pierre74LT New Member
    12
    Dec 28, 2012
    Qc
    I used Griffin rad (8-70010-ls) and Derale shroud and fan (16826) both parts from Summit
  9. mrfleet12
    mrfleet12 Veteran Member
    356
    111
    Aug 8, 2014
    West of Chicago IL
    I used the stock second gen rad as well, would prefer to go the route of the pass side upper at some point but this one seems to cool well for now.. Used a 2 piece upper hose since I added the steam vent line in the upper hose..
  10. 76z28
    76z28 Veteran Member
    2,052
    51
    Jun 29, 2009
    bakersfield
    Do you have a picture of that radiator? I am considering it
