What master would you use??
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by onerealZ, Apr 7, 2013.
  1. onerealZ
    onerealZ Veteran Member
    663
    Jul 19, 2004
    Poughquag, NY
    So seems like everyone has their own opinion on this, im going to be doing a ls1 rear disc swap on my 79, Ive searched about what master cylinder everyone uses with power 4 wheel discs and have seen a million answers. So from my searching what would be my best bet?
    80 T/a disc/disc master
    early 70's vette disc/disc master
    82 vette disc/disc master
    my only debate is i would like to keep my stock brake booster and some people say they feel the brakes are fine with the t/a master and stock booster?
    any help to clearify my searching would be great thanks
  2. DentDude
    DentDude Veteran Member
    417
    Apr 15, 2011
    Columbus,Ohio
    My 2 cents..at the end of the day,any of those set-ups will work as I've seen them all installed on various cars...and they work. On my 79 I'm still using the stock master/booster combo..it works fine,I just changed the proportioning valve to a 4 disc set-up. I think in theory you want a 1 1/8 bore master,but again,its not a must.My car is just a weekend cruiser,if you're building a competition car,you may wanna upgrade to 1 1/8 bore master for sure
  3. 5spd540
    12,379
    16
    Sep 19, 2009
    Guyton, GA
    I used a 79 T/A master when I had them on my car
  4. onerealZ
    663
    Jul 19, 2004
    Poughquag, NY
    hey 5spd why did you take them off? and i assume you used your stock booster with the t/a master?
