What OD Trans w/ 4.10 Gear?
Discussion in 'High Tech Retrofits' started by ATM, Apr 1, 2012.
  1. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    I have three vehicles I have built 700Rs for, all 3.73 gears. My 79 has drag radials and it won't even turn the tires over if you launch it in a straight line, it just dead hooks. I think the opinion that anything more than 3.73 is a waste with a 3.06 1st gear 700R is a generalization that only holds true for traction-limited cars. If you are running on rock hard 245 width street tires then that is probably a true statement but if your car hooks up, no reason I would not use a 700R with 4.10s. My truck is getting 4.10s very shortly.
  2. BonzoHansen
    19,331
    719
    Jun 1, 2005
    Scott from Hamilton, NJ
    T56, tko600, 4l80e, 200-4r would probably be my choices with that rear. I'd suppose the higher rpm the engine spins the more gearing you can get away with.
  3. ATM
    ATM Veteran Member Lifetime Gold Member
    2,265
    Oct 10, 2009
    Morris, Illinois
    OK, from the sounds of it I'll just keep my eyes open for whatever deal pops up then.
  4. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Buy whatever transmission you can that you can build up yourself the cheapest.
    That's what I'd suggest. Plenty of training materials out there to teach you the ropes. :)
    You're NOT that far from me, I can help you build one. IT's actually ALOT of fun to learn it.
    If it's a 2004R , I have all the materials here I can give you to copy. Even the CK performance manual.
    Jake helped me out with the over run clutch lathe part. Kewl Kat.
    I thought you just built your first last year ?? Damn......3 already ?? :D
    Awesome.
  5. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    Yeah I don't sit still for very long. I have built 3 or 4 rears since then as well.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Damn Bondo, you don't mess around.......that's fast.
    ATM (whats your name again ??) do you ever hit the Morris big shows ??
    We can meet up with Scotty out there, and I got a new guy I met with
    a badass LS3 78 Trans Am who lives down in Lisle I told about it too.
  7. ATM
    2,265
    Oct 10, 2009
    Morris, Illinois
    I go all the time, I met scott last time, I hope to get my engine done, and drive the car out there even as a project this summer.
