What radiator hoses do you use?
Discussion in 'High Tech Retrofits' started by 76_TypeLT, Dec 23, 2016.
  1. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    My radiator/fan setup is through Custom Works (motor is LS376) and one of the caveats is the upper hose needs to be spliced (98-2002 Camaro hose). Could I just use a flex hose instead? I am not completely averse to splicing a pre-formed hose, but think a one-piece hose would look nicer.
    There are tons of flexible hoses available, but are there any issues with using them? Any other ideas I should consider?
    Here's a shot showing the water pump I have, just for reference.
  2. larrylarry
    larrylarry Veteran Member
    1,544
    70
    Dec 22, 2011
    San Antonio Tx
    Measure your inlet/outlet sizes. The bottom outlet on my aluminum radiator was larger than the one on my water pump so I had to order a hose from Summit. Hose is ugly I know & a bit to long but it works.
  3. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I'd rather it work first and look nice second ;) Thanks for the info.
    Why do some water hoses have the green line on them? My heater hoses have the same thing.
  4. badazz81z28
    16,418
    407
    Las Vegas, NV
    I used a metal corrugated hose on my 78 and hated it. You need a steam line anyways. I would splice it.
    Use this
    www.finchperformance.com
    Scroll down to the steam port adapters
  5. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I have a dedicated inlet on the radiator for a steam line, so that won't be an issue.
  6. 71RS/SS396
    71RS/SS396 Veteran Member
    2,624
    27
    Aug 26, 2008
    Wake Forest NC
    The radiator and accessory drive being used is going to be a factor. I have a C&R radiator and Wegner Motorsports drive, I used the Gates 21347 for the upper and the Gates 22437 for the lower, iirc I had to do some trimming on the hoses at the ends.
  7. hot72rod
    2,990
    36
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    Here is the lower hose I used.
    Now this lower hose will work one way but if you turn it upside down it will not work. As for your top hose, I would almost think the one form a 76 v8 Camaro would work since your are using a LS3 water pump.
  8. hot72rod
    2,990
    36
    Aug 9, 2000
    Also what side is your top outlet on the drivers or passengers?
  9. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    So that is a Gates 20734 hose. I think I can use a 98-2002 Camaro upper hose, at least I was told that by someone who I trust.
    FWIW, the Gates 20734 is apparently equivalent to the Dayco 71916 hose. According to Gates, this hose fits the 1969-89 Ford E Series Van, which seems odd.
  10. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    Inlet and outlet on the radiator are both on the passenger side.
