What sensors for LS1 intake?
Discussion in 'High Tech Retrofits' started by OsborneConst, Jul 23, 2012.
  1. OsborneConst
    OsborneConst Veteran Member Lifetime Gold Member
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    Here is a picture that shows it. It looks like some sort of plate or something.
  2. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    That is the early LS1 intake up to 2000, the plate is the block off for the EGR tube that was originally plumbed there. After 2001 the LS1 and LS6 is the same manifold that did not require an egr system as the engine controls and calibration got that good.
  3. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    If you are using the LS1 injectors, the plugs on your truck harness that plug onto them will need to be changed. The injectors for a LS1 are different than the truck's. Simple fix is get the plug's from a junkyard and change them on your harness.
  4. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    Thanks, that is what I kind of *assumed*, but wasn't sure. The pic is one I found on the Internet, not mine, so I just need to get a block off plate then?
  5. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    Thanks. I ran into that issue a while ago, and have already got the wire harness switched around. It would have been good to know that before though!
  6. ryeguy2006a
    ryeguy2006a Veteran Member
    157
    Sep 29, 2009
    Upstate, NY
    Search google for EGR delete and there are many different ones out there. There are some cool ones on ebay that have different engravings on them. I need to get one of those eventually.
