What shifter for factory console and 4L80E?
Discussion in 'High Tech Retrofits' started by OsborneConst, Jan 8, 2012.
  1. OsborneConst
    OsborneConst Veteran Member Lifetime Gold Member
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    I have done some searching, and haven't really found any information. What aftermarket shifter(s) will fit in the stock console, and work with a 4L80E?
  2. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    You might check with Shiftworks to if they offer a modification to a stock style ratchet shifter for a stealthy installation.
  3. Fbird
    4,152
    694
    Feb 12, 2011
    atlanta, ga
    ^^^^ the stock one!
  4. JAMMINJ007
    JAMMINJ007 Veteran Member
    397
    Dec 27, 2005
    Houston, Tx
    I am using a B&M Quicksilver! ;)
  5. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    I am building the car for a street car, and will probably be my daily driver in good weather, when I don't need my HD. However drag racing is my passion, so it will definately see plenty of track time too. I raced it when I first got it with the stock 'ratchet' shifter in it. It was pretty cool for a stock shifter from the 70's, but I don't think I liked it well enough to use it in competition.
  6. Battmann
    Battmann Veteran Member
    704
    Sep 12, 2007
    North Chili, NY
    i'm using a B&M megashifter that was made for a third-gen f-body. my camaro is a 1972 so not sure how that would look / fit if you have a different middle console. here's a picture:
  7. 2ndgenhunter
    2ndgenhunter Veteran Member
    798
    Mar 19, 2010
    Blairsville,GA
  8. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
    I used a shiftworks kit, easy to install and factory look
  9. RagTop454
    RagTop454 Member Lifetime Gold Member
    59
    Feb 24, 2007
    Ten Mile, TN
    If you're wanting a ratcheting shifter, I don't believe the Shiftworks kit will do it for you using the stock shifter. Although their kit will give you detents for 4 forward gears, it does not add a stop for the ratchet function when shifting into 4th gear. They have the following posted on their website under "Detent Comparison":
    "4-speed overdrive conversion Park and Low are in the same location as the original equipment. Use of the "Rally" shifting should be tested individually with the engine off. The conversion was not designed for, and does not include any provision for, use of the "Rally" shifting option. Continued use of this option should be tested with the engine off. There will be NO STOP for the Overdrive."
    I agree that even in stock form, the stock shifter, ratchet or standard, is not very well suited for competition as it leaves too many ways for me to do the wrong thing and break stuff. To the best of my knowledge, the B&M Quick Silver and MegaShifter are the only ratchet shifters still made to both fit our consoles and operate a 4 speed auto trans.
  10. OsborneConst
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    Thanks for all of the info. When I posted this I was having a brain fart and thought that the 4L60E and the 4L80E needed a different shifter than the 700R4. I think I will be going with the Quicksilver.
