What shocks do you recommend for this set up
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by perkalator, Oct 24, 2016.
  1. perkalator
    perkalator Veteran Member
    1,025
    90
    Aug 27, 2014
    kennewick wa
    I've ordered Eibach 2" progressive rate lowering springs for the front. It will have stock arms and poly bushings. The rear will be a hotchkis 2408c 1.5" lowering kit to include shackles and everything. I'm looking for a good ride on the street and the occasion hard launch for fun. What brand and length shocks are you running with a similiar set up.
  2. Lowend
    15,019
    485
    Mar 25, 1999
    San Jose, CA, USA
    I've never heard of Dina Hair springs before
  3. perkalator
    1,025
    90
    Aug 27, 2014
    kennewick wa
    Auto correct stinks. Eibach. I made it in to edit before the 30minute window.
  4. CorkyE
    10,402
    484
    Bilstein, Koni, Viking, just to name a few to start with, With shocks, they get better the more you pay for them. I've heard to avoid KYB, and I haven't tried them. I can say that with delrin bushing on the front, you can move the a-arms with you finger.
  5. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    15
    Sep 16, 2012
    NorCal
    That's the same setup I'm running except I have steel bushings in my lower arms and aftermarket adjustable upper arms. For shocks I got mine from Keith at Customworks. They're AFCO's and I love my combination.
  6. perkalator
    1,025
    90
    Aug 27, 2014
    kennewick wa
    Thanks also does anyone have the compressed and extended lengths of the shocks their using with roughly a 2" drop all the way around
  7. Lowend
    15,019
    485
    Mar 25, 1999
    San Jose, CA, USA
  8. CorkyE
    10,402
    484
    If you're concerned these shock will bottom out with 2" drop springs, I have not experienced that issue. I'm at least 2" down all the way around using Koni shocks and would expect others to be the same.
  9. perkalator
    1,025
    90
    Aug 27, 2014
    kennewick wa
    Thanks corke, i think ive decided on the hotchkis 1.5 shock kit. Man what happend to the days when you could by good shocks for 40 bucks each. Lol
  10. John Wright
    14,701
    212
    Aug 9, 2002
    Rustburg, Va
    Me too...I have the white body KYBs currently and they are stock length but my car is quite a bit lower....rides good, no bottoming. I have a 700# spring in the front now, but even with the previous lesser rate springs, I never did bottom the shocks out. The front tires hit the fender liner before the shocks or suspension bottomed out.
