What spark plugs do you use? BBC or SBC
Discussion in 'Engine Topic' started by VW_Factor, Aug 30, 2012.
  1. VW_Factor
    VW_Factor Veteran Member
    232
    Jun 4, 2012
    Leesburg, GA
    You got a BBC or SBC.. What plugs are you running in it?
    Non-standard or custom heads should probably be mentioned as it plays a factor.
    Preferred brands? Whats working for you?
  2. ThumperZ28
    ThumperZ28 Veteran Member
    1,018
    Nov 8, 2008
    Oceanside,California
    355 9.5:1 compression lunati mild cam
    Edelbrock heads
    AC Delco gapped at .033.... H.E.I
  3. Smokes
    Smokes Veteran Member
    391
    Feb 5, 2012
    Missouri
    406, iron eagle heads, 10.4 compression
    NGK V-Power -7 heat range gapped at .040" HEI
  4. Rich Schmidt
    Rich Schmidt Veteran Member
    4,004
    Mar 27, 2010
    Denville NJ
    I run a bigblock with GMPP aluminum heads. They use the .750"reach(long thread) gasket seat plug and need the smaller 5/8" head for a socket to fit on. I use Champion race plugs because I dont want a resistor. It may or may not interfere with your radio/electronics,but usually not as bad as solid core wires. In my case my engine is a race engine that has a little too low of compression ratio for the cam I have so I run a bit hotter plug then race engines usually use. I have a C59CX which seemed to run better and stay clearer then the C57CX's that I used to use.
    Many aftermarket aluminum heads use the gasket seat plugs that require the special 5/8" hex. I later found that aluminum headed Corvettes also use this plug type and I could run Delcos or anything else I wanted for much less money.
    On my hot rod street car it has a slightly too high compression with factory iron heads,and I run cheap Delco R45T's with a stock points distributor,Crane electronic conversion,Crane coil and low resistance wires.
    I have found that the ignition system is more important then the plugs as long as the plugs are the proper heat range. Plugs foul when the gap is shorted out from too much fuel,or oil in the chamber. A strong igintion system plus low resistance wires really helps this.
    I dont run trick plugs on my serious go fast race stuff. The trick plugs that have pointy little electrodes and ground straps ect are going to melt way faster and run much hotter then a regular plug that has some meat on it. Plugs getting hotter from tiny little ground straps and tiny platinum electrodes is a sure fire way to cause detonation.
    Thats just my experiance.
  5. Z28zz383
    Z28zz383 Veteran Member
    761
    May 11, 2012
    Florida
    I have the fast burn heads GMPP 383. Started out with the R-42LTS Seemed to dark. Changed to R-44LTS ac delco's Seems to burn cleaner....Not too bad priced platinum plugs. GMPP recommends these two plugs for this motor, #42 is race and colder, #44 is street and next size warmer. gapped at .040 GM Performance HEI dist.
  6. COPO
    15,435
    86
    Toronto Maple Leafs
    AC R43 70 LT1 2.02 heads.
  7. 496z28
    496z28 Veteran Member Lifetime Gold Member
    959
    Sep 23, 2007
    Oklahoma City
    R45TS delco. 496, 460, 468 big blocks
  8. 80WA7113
    80WA7113 Veteran Member
    1,362
    May 22, 2002
    Indianapolis, IN
    AC R44T all stock 1973 SBC 350
  9. 73RSZ/28
    73RSZ/28 Veteran Member
    233
    Aug 26, 2008
    St. Peters, MO
    Dart Pro 1 NGK BKR6E.
  10. tubewade
    tubewade Member
    88
    Sep 22, 2010
    Oklahoma City
    I have several engines with 781, 049 and 215 heads. For the tapered seat heads I use AC R44TS or R43TS and for the long reach gasket plug heads (the 215s) I use R44XLS.
