What tank of high hp applications
Discussion in 'High Tech Retrofits' started by Power, Feb 13, 2014.
  1. Power
    Power Veteran Member
    119
    Jan 20, 2014
    Oregon
    I'm doing a turbo build on my street car. Is there a stock replacement that has a built in fuel pump that will hold up to 600-650rwhp? I know I could get a out side pump and sump my current tank but I'm having a hard time finding a local shop to cut and weld on a used tank?
  2. global warmer
    global warmer Veteran Member
    494
    Apr 1, 2010
    Saratoga Springs NY
    look up aeromotive stealth tank it's a drop in pump for the stock tank supports more then 650hp
  3. mrvedit
    mrvedit Veteran Member
    1,355
    Jun 12, 2009
    Ann Arbor, MI
    I think Global_Warmer meant the Aeromotive "Phantom 340 Pump" which fits any stock tank.
    Aeromotive is also starting to make complete tanks with that pump available for a variety of cars. Mostly A-body. They list one for 67-69 Camaros too, but nothing yet for Gen-2.
    My current plan is a brand new tank for my '81 and the Phantom 340.
  4. pronova1203
    pronova1203 Member
    48
    Nov 8, 2012
    newaygo mi.
    wash the tank out with water , pump co2 from a small engine exhaust into it and find a buddy to weld it up, ive done several, other option is new tank, or fuel cell, alot of giys running the bosch external in single or dual to 6-800 hp some are doing triple internal pumps in the factory tanks , i dont like pulling tanks down for pump malfunction;)
