what throttle cable for ls1 in a 79?
Discussion in 'High Tech Retrofits' started by brownz, Oct 3, 2010.
  1. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    I guess it appears the 36" might be too short. I may have to do that.
  2. andrew69_04
    andrew69_04 Veteran Member
    254
    Jan 8, 2012
    Berthoud CO
    for those of you running the cable off an F-body, make sure you get the cable for a non ASR-TCS (traction controlled) car as the 2 cables are totally different
  3. studsZ28
    studsZ28 Veteran Member
    115
    Feb 19, 2008
    MN
    For mine, I used a factory throttle cable from a 2001 Silverado, i just have to slightly modify the factory LS1 throttle cable bracket and then crimp a cable stop onto the cable at the pedal. I used my scan tool to get it in just the right spot where there is absolutely no delay in opening the throttle, and it gave me excellent throttle response.
