what to do with IAT sensor for LS1?
Discussion in 'High Tech Retrofits' started by la-rue, Mar 11, 2014.
  1. la-rue
    la-rue Veteran Member
    437
    Sep 30, 2013
    SF Bay Area, Ca
    what should I do for this sensor? I'm just using silicone couplers and some stainless tubing for my intake setup, so I'm not sure how to add this.
  2. camarochevy1970
    camarochevy1970 Veteran Member
    7,768
    46
    Jan 23, 2003
    Pittsburgh, PA
    The ECU absolutely needs it, so either make a spot in the intake tube for it or find some other way to get it into the intake path
  3. PolarBear
    1,189
    Apr 24, 2008
    NJ
    I'm using a truck MAF with the IAT built in, but you can just mount the IAT in the tube with a gromet. I would add it in front of the MAF in case there is a leak past the gromet you don't have any un-metered air entering the engine
  4. mrvedit
    mrvedit Veteran Member
    1,355
    Jun 12, 2009
    Ann Arbor, MI
    I got tired of heat soak and ended up mounting it just behind the passenger side head light. Obviously the wiring to it had to be extended. In other words, my IAT is reading ambient temperature, not the actual air coming in.
    I log (with HP Tuners) and fine-tune every week and found this the most reliable temperature pickup point.
    In the OP's picture I looks like the IAT location is in front of the radiator, which should reduce, but not eliminate heat soak.
  5. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
    Use the 91 gmc cyclone iat sensor works perfect same plug harness and uses 3/8 npt thread in style just weld a 3/8 bung into ss section
  6. MalibuSSwagon
    MalibuSSwagon Veteran Member
    113
    Nov 15, 2010
    so. NH
    I am also using the truck MAF with IAT built in. It's simple, clean solution.
  7. la-rue
    437
    Sep 30, 2013
    SF Bay Area, Ca
    thanks for the suggestions. I'll look into the truck MAF. what model/year trucks will have the MAF that works?
  8. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Integrate it with the MAF. Buy the Z06 or truck 85mm MAF and re-pin it.
  9. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    ^^^^ +1 :)
