what water hoses and water neck did you us for your LS swaps??
Discussion in 'High Tech Retrofits' started by QUAKE_WARS, Dec 17, 2016.
  1. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,025
    149
    Dec 19, 2008
    USE for your LS swaps.. Not us. Edit would not let me correct title
    I am going to be using my original 3 core radiator. What options do I have on water hoses and water neck do I have. Did you tap out your heater hose nipples also? Right now I have the truck water neck but its removed in the pic.
  2. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,390
    84
    Feb 2, 2008
    SF
    I used factory hoses on mine
    I think I had to cut the lower one to fit though
  3. junkyardZ28find
    790
    8
    Mar 4, 2012
    des moines, iowa
    If you're using electric fans, I've been making tapped upper radiator hose aluminum adapters for use with a BMW dual temp fan switch-makes it easy to use the 14mm switch.
  4. QUAKE_WARS
    2,025
    149
    Dec 19, 2008
    Yea, Im using a 1997 Trans am LT1 dual fans.
  5. junkyardZ28find
    790
    8
    Mar 4, 2012
    des moines, iowa
    I'm using a 1.5" hose adapter with a drilled/tapped 14mm bung for using the BMW switch-I'll gets some pics of the setup shortly.
  6. QUAKE_WARS
    2,025
    149
    Dec 19, 2008
    NO ONE!!!!! :lush:
  7. Pierre74LT
    Pierre74LT New Member
    12
    Dec 28, 2012
    Qc
    for my heater hoses i used dayco 80405 (5/8)and 80416 (3/4) they are both molded with a 90 degree bend
  8. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
  9. hot72rod
    3,017
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    The NPT size are 1/2 and 3/8.
    As for the water neck I use an LS1 neck but it looks just like the truck neck and this is the lower hose I used.
    Now this hose will only go on one way and work.
  10. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I bought that lower hose on eBay for $14 shipped. Not too shabby. It was advertised as a hose for a Mazda, but the picture was clearly the hose I want, so either I got a decent deal or they are sending me the wrong hose, lol.
