what would my compression be?
Discussion in 'Engine Topic' started by mark wagner, Jan 19, 2019.
  1. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    I have a low mileage crate 350 short block. heads are long gone, but I have a pair of 88 corvette aluminum heads ('113 castings) which are 58 cc chambers. The block has stock dished pistons. what would I expect to get for a comp ratio? roughly. and what would be a good camshaft to use in it? just want a decent running cruiser that I can light up the tires when I want to.
    thanks
  2. Zspoiler
    Zspoiler Veteran Member
    3,265
    264
    May 6, 2012
    Federal Way, Washington
    Just look up how to figure compression ratios that SBC that should help you
  3. rchydzik
    836
    23
    Nov 13, 1999
    Colbert, WA USA
    Assuming a 12cc dish, and 58cc chambers, 0.025 inch deck height, and factory 0.015 inch head gasket, 10.1:1. If you go with a typical 0.038 inch head gasket, 9.6:1.
    mark wagner likes this.
  4. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    178
    76
    Feb 5, 2016
    Sarasota,FL
