whats up with everyones lsx projects?
Discussion in 'High Tech Retrofits' started by RICARDO1969, Sep 17, 2011.
  1. 73Z L92
    73Z L92 New Member
    27
    Jan 25, 2011
    Carlos, MN
    Just quick note to Jamminj007. A friend of mine bought a iron block 6.0 with a broken pan. 3000 mile engine. Replaced the pan put it in his Nova and after running it he found out the back of the block was cracked. Hair line crack just to the left of the rear cover about in the middle block. The casting must be real thin in that area.
    Make sure you check your block carefully. That pan is tough and when it takes a hit that force is transfered directly to the block.
  2. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Yup, thats what I have read (and mentioned earlier in the thread). If you got
    out there and took pictures and built your case against the Road Maintainence
    division of your States Government, you could get a check to fix it. Also this
    should be covered by your auto insurance (its a collision). Your insurance will
    payout and then go after the State for money.
    Tom
  3. JAMMINJ007
    JAMMINJ007 Veteran Member
    397
    Dec 27, 2005
    Houston, Tx
    Well I will know in about a week. I have a break from school and I was hoping to yank it out ; put all back together and have it running by the time I go back to school. I surely hope it didn't crack the block:mad:
    I put it on a lift and did not see a crack in the block, but I did see where it broke the backplate.
  4. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Did you go back to the scene of the accident and take documentation? Do
    you have witnesses that can back up the event?
    Tom
  5. 73Z L92
    73Z L92 New Member
    27
    Jan 25, 2011
    Carlos, MN
    The crack in the 6.0 was small enough that just looking you couldn't see it until we took a small buffing wheel and cleaned up the back of the block. Magnafluxing would find it in second. May be worth doing just to be sure.
  6. patgizz
    patgizz Moderator Lifetime Gold Member
    12,737
    Apr 10, 1999
    Cleveland
    since the 80z i had was a rotten POS i bought a 95 impala ss and put my lsx in that. fun times.
  7. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    once my 51 arrives i just may put my entire lsx set up in it :) hmmmm?
  8. 2ndgenhunter
    2ndgenhunter Veteran Member
    798
    Mar 19, 2010
    Blairsville,GA
    My LS 5.3 is sittin next to the computer holding my pizza while I wait for this damn rain to stop so I can finish my floorpans. I might have it in before the car turns 40.
  9. 70UglyBird
    70UglyBird Veteran Member
    206
    Apr 1, 2010
    Portland
    Dude we need more details. I've wondered if a TVS would somehow fit under a stock hood. I think you have a little more room under yours than my firebird but that thing is going to be a beast.
  10. brownz
    brownz Veteran Member
    649
    Jan 12, 2007
    Ohio
    Mine is on hold for a bit, its getting close but I'm going to cut it up again for some DSE mini tubs and some...:cool:
