Whats Your Fastest Time With A Hydraulic Flat Tappet Cam.
Discussion in 'High Performance Modifications' started by lazr_guira, Jan 12, 2010.
  1. lazr_guira
    lazr_guira Veteran Member
    199
    Feb 9, 2009
    IL
    Hi all. I was just wondering how much power can someone get out of a hydraulic Flat Tappet Cam on a SBC. How many of you were able to get into the low 12's 11's or even 10's... I would really like to know.
    Post your setups if you don't mind::bowtie:
    Which cam?
    Engine displacment?
    Heads?
    Compression ratio?
    Car?
    Car wieght?
    Gear ratio?
    Trans?
    Stall?
    Carb size?
    Intake?
    And anything else you you like to list. If you run a solid flat tappet you can post you setup too also. Thanks guys....
  2. GoldenOne7710
    GoldenOne7710 Veteran Member Lifetime Gold Member
    4,049
    92
    Jun 23, 2004
    Athens, GA
    Where's nightrider at? John to the front please....
  3. Southern72
    Southern72 Veteran Member
    589
    Mar 2, 2005
    Devestation,La
    Well I went 12.42 with a voodoo 268. This is in a streetcar no race trim.Switched to a bigger hydro roller and went 11.66 with the same setup. If you don't want to go roller why not a solid FT?
  4. lazr_guira
    199
    Feb 9, 2009
    IL
    Nice...I'm just curious to see other people's acomplishments.
    Thought it would be cool to see... I'm thinking of swapping the HYD. for a Solid Flat Tappet in the 355 so i can use the same valve train.
    The roller cam i will use in the 406 instead.
    For some reason i really feel like trying to see if i can break into the 11's with the comp cams 294H. I did it before with my other camaro 10 years ago with a crane ENERGIZER 302H and 11:5:1's. (car went 11.94)
  5. Dirt Reynolds
    Dirt Reynolds Veteran Member Lifetime Gold Member
    3,625
    Jan 17, 2003
    BC, Canada
    Hydraulic flat-tappet....quickest I went was 12.15/110.5 on drag radials in my '77 Z-28. 400 small block, Vortec heads ported by me, Crane 234/244, 2800 stall, 4.10 gears. Car weight with me in it and 1/2 tank fuel was 3750 lbs. Launch was off-idle and it was in mid-July, very hot temps.
  6. Mwilson
    Mwilson Veteran Member
    12.54 @ 107
    Lunati bracket master 300/515
    355ci 9.8:1 camel hump heads
    3310 carb
    rpm intake
    th350 2,500 stall 4.10 gear
    full 2.25" exhaust
    3,500 lbs
  7. 79_406camaro
    79_406camaro Veteran Member
    131
    Nov 29, 2009
    durant, ok
    400ci solid flat tappet, 259-269 at .050 563-584 lift 106 lsa, 11:1 compression, patriot heads, 750cfm holley, super victor intake, th350, 3500 redneck converter, 3.42 gears, 27in tire, 3500lbs, with a spun rod bearing it went a 11.62 at 116mph, 1.68 60ft. < rotten. And it was 90degrees. Hope this helps
  8. muscl car
    best time for my camaro last time i raced was 12.60 @ 106mph and that was 10 years ago
    Which cam? GM #140 mech flat tappet 257/269@ 0.050 , 493/512 lift 4200-7200rpm
    Engine displacment? 350sbc
    Heads? #186 cyl heads w/port & polish work done
    Compression ratio? 11.1:1 comp
    Car? 72 camaro ss
    Car wieght? 3500lbs
    Gear ratio? 3.42's
    Trans?T350
    Stall? 2600
    Carb size? holley 750dp
    Intake? edelbrock TM-1 tarantula
  9. z28rod
    z28rod Veteran Member
    4,473
    Apr 30, 2009
    hopewell junction,ny
    406 sbc ran 12.99 at 105mph , sportsman 2 heads fully ported, crane energizer 272 h10 cam 454 int/exh , 650 d/p, wiend stealth int. , 11-1 comp. 3.42 gears, street tires with 2k converter. car weight with me in it 3900 lbs.
  10. lazr_guira
    199
    Feb 9, 2009
    IL
    very nice guys this is what i wanted to see... keepem coming. I just looked up NIGHT RIDER's old post which is pretty damm impressive for a 355:D its a solid thow but still quite an acomplishment. Cheers to you.... where ever you are NIGHT RIDER !!!
