wheel tubs
Discussion in 'Competition Camaros' started by kevprue21, Oct 18, 2011.
  1. kevprue21
    kevprue21 Member
    39
    Mar 16, 2011
    North alabama
    has any of yall used any of the wheel tubs out of summit.if so how are u putting them in.they are made of some crappy metal that will not weld right.any advice.what are yall useing.
  2. Fbird
    2,357
    77
    Feb 12, 2011
    atlanta, ga
    theres a whole lot of nothing said ^^^^^
    1) what r u using to weld with
    2) can u weld sheet metal? cause tubs are usually NOT welded in (i've never welded a set always used rivets or rivetscrews)
    3) what r u welding them to?
  3. Fbird
    2,357
    77
    Feb 12, 2011
    atlanta, ga
    oh yeah....there is probably a rust preventative coating on the STEEL tubs!!!
  4. kevprue21
    kevprue21 Member
    39
    Mar 16, 2011
    North alabama
    ok there is some thin on it because all it wants to do is spit in pot and blow threw.i can weld prety thin stuff with a mig with gas on it.this is my first wheel tubs.so u pot rivit them in to the frame and whats left of the old wheel well.
  5. kevprue21
    kevprue21 Member
    39
    Mar 16, 2011
    North alabama
    This is my first wheel tubs.So if i need to rivit them in can somebody show me a picture of theres to see if i am doing it right.thanks
  6. harbone66
    3,302
    185
    Feb 15, 2011
    Central Illinois
    The tubs I received from Summit on the 68 Camaro I tubbed 4 years ago were aluminum, I riveted them in and used seam sealer/adhesive to glue them to the inner quarters.
